Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2006-03-22, 20:57   #1
duster70
Member
Vehicle(s): 1970 Maverick I-6 automatic
Images: 8
car turns off when i put it into gear
car is an automatic column shift. this is what happens. The car is on park and i turn it on. When I change into drive or reverse, the car turns off. I bought the car with almost no gas at all and i havent filled the tank yet, so maybe its just that it doesnt have any gas. I wont get to see the car until the weekend and then I will fill the gas tank. Anyhow lets say when I fill the gas tank all the way it still turns off when i change the gear. I remember the previous owner saying that something might be wrong the carburetors timing or something like that. what do yall think the problem is and how could I fix it? any possibility it could actually be that the car has almost no gas?
duster70 is offline   Reply With Quote
Sponsored Links
Old 2006-03-22, 21:05   #2
sierra grabber
Certifiable
sierra grabber's Avatar
Vehicle(s): 71 grabber red and black; 74 2dr LDO comet
Images: 22
sounds like it needs a tune up. best guess without being there. are you letting it warm up before you put it in gear?
__________________
"@#%$ holding on...Start Praying!"
I'm not a sheep, grab life by these horns!
71 mav Grabber
74 Comet
73 F250 High Boy
83 honda magna v65
06 subaru outback sport
sierra grabber is offline   Reply With Quote
Old 2006-03-22, 21:23   #3
bartikus
Member
bartikus's Avatar
Vehicle(s): 1973 comet, 1977 4 door mav(dead), 1964 falcon 4 door wagon, 1936 studebaker dictator, 1981 chevy k10 short bed
maybe it's idling too low. that would be my best guess. it sounds like it's idling high enouph to start but once you put it in gear the idle drops too low to keep it running.
__________________
if it's too loud your too old
bartikus is offline   Reply With Quote
Old 2006-03-22, 21:53   #4
duster70
Member
Images: 8
how do i change the idle speed??
Old 2006-03-22, 22:16   #5
blugene
Senior member
blugene's Avatar
Vehicle(s): 73 Comet GT, 75 Comet, 72 Comet GT, 2008 "Comet" (our boxer)
Images: 55
Cool
Only change the idle if it's not within the normal range. I would say 550 to 700 rpms should be ok. There are several reasons why the idle might be out of spec. if it is. I would check things like timing, vacuum leaks, cap and rotor, wires, coil. Rarely is it a simple adjusting of a screw.
__________________
blugene is online now   Reply With Quote
Old 2006-03-22, 22:21   #6
GTwannabe
Member
GTwannabe's Avatar
Vehicle(s): 94 mustang GT, '73 Comet GT 302 toploader 4-speed
check for vacuum leaks and that the choke is opening.
GTwannabe is offline   Reply With Quote
Old 2006-03-23, 06:14   #7
igo1090
Member
igo1090's Avatar
Vehicle(s): 75 maverick, 93 tbird tube car
i wouldnt fill it. put 5 or 6 gal in it. just incase it turns out to be a clogged tank pick up. its a pain having to take out a full tank. or pump it dry first.
__________________
dave shea
s/st 1818, h/r 1564, s/p 1018
igo1090 is offline   Reply With Quote
Old 2006-03-23, 08:18   #8
71gold
Frank Cooper
71gold's Avatar
Vehicle(s): '73 Grabber
Images: 45
you say "turns off"...does this mean...it dies... are the dash lights on when "it turns off"?...frank...
71gold is online now   Reply With Quote
Old 2006-03-23, 08:41   #9
don graham
Senior Member
don graham's Avatar
Vehicle(s): 70 mav, 71 grabber, 73 mav, 73 Comet, 2004 f-250 crew cab diesel, 98 taurus, 2001 montana
Images: 12
i would suspect a vaccuum leak. also check the fuel lines and filter. could be clogged and not getting enough gas. does it run okay if you rev the engine up? make sur the line is not kinked. like was said don't fill it up. just put about 5 gallons in it until you get it figured out.
__________________
don graham q751
don graham is offline   Reply With Quote
Old 2006-03-23, 13:10   #10
Radarlove
Novice
My car was column shift as well, and when id put it into gear it would idle down and shut off, like everyone else said check for vacuum leaks and choke.
Radarlove is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
So I drove the Maverick to a car show yesterday.... Rick Book General Maverick/Comet 25 2006-08-20 21:45
Well, I did it! This is one awesome car! rayzorsharp Maverick & Comet Auctions, Craigs List and other Classifieds 52 2005-10-25 12:15
Car show pics rayzorsharp General Maverick/Comet 24 2005-02-16 08:28
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
