Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2006-07-04, 15:29   #1
mean_maverick
Senior Member
mean_maverick's Avatar
Vehicle(s): '73 4dr
Images: 15
302 engine block drain plug/freeze plug...???
i kept noticing a slight amount of coolant gone from the radiator after a couple of days of sitting, well since im off for the 4th i thought i would just get outside and enjoy the day tinkering with the car. well, i found out where the water was going....(and i also think this is the main part of my overheating problem)
there's a hole on the driver's side of the block, near the back that was leaking. i took my header off of that side and put a small screwdriver in it and all kinds of 'gunk' came out. i cleaned the hole out ad everything and i went to put a 1/2" freeze plug in it only to notice that it didnt fit right. so i thought it might have been a threaded hole so i tried a threaded plug... no luck. it doesnt look like there are any threads in the hole.
so here's my question, does anyone on here know if this is a threaded or non-threaded hole. and maybe what size plug i need to get for it...? any help on this matter would be greatly appreciated
__________________
1973 Maverick 4dr, 302/auto
1971 Grabber Blue 2dr 5.0/T5 -SOLD-
2003 Ford Mustang Mach 1, Azura Blue, Built, Blown & Stroked 562hp/501tq
http://73grabber.webs.com/1973grabberregistry.htm
mean_maverick is offline   Reply With Quote
Sponsored Links
Old 2006-07-04, 16:30   #2
igo1090
Member
igo1090's Avatar
Vehicle(s): 75 maverick, 93 tbird tube car
not threaded. did u get out all of the old freeze plug? hole must be clean. go get a rubber expansion type plug u put it in the hole and tighten the nut to expand the rubber plug. i forget if u need 1 1/2 or 1 5/8 inch size. these are much easier than trying to drive in a freeze plug in a cramped space. ive had 1 in my motor for 3 yrs now
__________________
dave shea
s/st 1818, h/r 1564, s/p 1018
igo1090 is offline   Reply With Quote
Old 2006-07-04, 16:45   #3
RegL404
Member
That hole to the right of the brass freeze plug looks like a block drain. I think it is supposed to be 1/4" pipe thread.
RegL404 is offline   Reply With Quote
Old 2006-07-04, 17:19   #4
71gold
Frank Cooper
71gold's Avatar
Vehicle(s): '73 Grabber
Images: 45
why do the pics. have an 8/01/2005 date ...frank...
71gold is offline   Reply With Quote
Old 2006-07-04, 17:37   #5
mean_maverick
Senior Member
Vehicle(s): '73 4dr
Images: 15
i've never set the date one the camera .... and yes, im referring to the small hole in the pictures BESIDE of the brass freeze plug.
__________________
Old 2006-07-04, 17:41   #6
MNTony
aka Stinky
MNTony's Avatar
Vehicle(s): 72 Turbo FI Maverick, 2001 Dodge Cummins 4x4
Images: 1
That hole is threaded in my block and has a pipe plug in it. Not sure why yours doesn't look that way? The rubber expansion plug may not be a bad idea if you can find one the correct size. Good luck!
__________________
There was a time when guys built race cars out of old street cars. Today, guys build race cars out of American Express payments. Unfortunately I build garage queens out of perfectly good cars.
MNTony is offline   Reply With Quote
Old 2006-07-04, 18:55   #7
igo1090
Member
igo1090's Avatar
sorry. thought u meant the freeze plug hole. drain hole is usually 1/4 npt. try a cleanout tap and a new plug.
__________________
dave shea
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
mercury 302 engine Jzap99 Parts Interchange 11 2009-09-20 23:17
1976 302 engine missing Komet302 Technical 23 2003-05-31 02:50
1974 302 maverick spak plug gap 302Jim Technical 1 2003-05-16 17:43
what year 302 block? PINKY Technical 4 2003-02-26 13:18
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
