Triple cannon gauges
Discussion in 'General Maverick/Comet' started by blugene, Aug 6, 2006.
  1. blugene
    I think that is what I will name them when they are done.
  2. maverick75
  3. Mavaholic
    Looks good, how are you going to mount them?
  4. blugene
    I'm still working on them. Mounting them will be tricky, but me :D .
    I need one more can to keep going. Hmmm...Should I add a trans one? :drink:
  5. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    yes...and take pics so it will make my install easier :D
  6. blugene
    :eek:Coppy cat!!:drive:
  7. blugene
    If I can get a matching one without fluid going into the car I will :drink:
  8. Rando76
    Rando76 Member
    Claremore, OK
    Cool. Where are you going to mount them?
  9. blugene
    Still playing with them... Death in family slowing me down... Will be full blast back on it by Monday, unless I get a gate call.
    I was checking out some options and have discovered the length to be a great factor in the final decision on this one. I might have to go with the snubed cannon look... I placed them in the tray and there not eye pleasing, I mean eye leval:D .
    I will be needing to get two more of either can, so... on the cowl or on the dash? On the cowl I will have to make some sort of fancy brkt that will be bling bling, I guess... Inside can be a bolt down not too fancy one. Care to give opinion?
  10. blugene
    Here is the difference in size... And not the stainless look on the snub:(
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    I am not feeling any of them locations.
  12. blugene
    Hmmm... should I hole cut through the face of the dash just to the right and project them out? Inside/outside, what? I do like the racy look... which looks fastest :drive: :D
  13. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    thats what I was thinking....outside does look "faster" maybe the small can would look different. but I think you might run into clearance issues on the cowl...got to open the hood every now and then :D
  14. cometkurt!
    cometkurt! Member
    south paris maine
    mabee you can hide them under a rear induction scoop on the outside. that would look b*chin!
  15. Mavaholic
    Never cared for cowl mounted gauges. Remove the ash tray and mount them in that area, angled towards the driver.
