What goes here?
Discussion in 'Technical' started by Zooomzoomguy, Aug 22, 2006.
  1. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    well, i'm in process of assembling my engine, and kind of fogot where some of
    my brackets go, could you guys help me figure this thing out? i added arrows
    to indicate my confusion areas, and if you see something out of place please
    let me know, i've also noticed that my water pump seems to be missing a hole
    or something since my timing cover has 3 holes on top, water pump only two (see pictures). thanks (y)
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    On the
    1st picture any hole with threads are accessory holes. No threads requires a bolt
    3rd picture that is your oil pressure port
    4th picture on bothe heads the larger hole is the Thermactor port. If you don't have an air pump (doubt it) these will need to be plugged or it will have an exhaust leak. These are a special thread. You can get the plugs from a Ford Dealer part number F4ZZ-6E086-A, you will need a total 4 of them I think they come 2 to a pack. The other 3 holes are accessory mounting holes
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Picture one and two ... Put a bolt in the water pump holes ... if there is a thread then there should be a bolt. Some bolts go into the timing chain cover ... others go all the way to the block so make sure you have the right length bolts in the right place.
    Picture three is for the oil pressure sender.
    Picture four are the holes to mount the alternator bracket on the head.
  4. maverick1970
    Missouri
    Other than the alternator what do you have, AC, Power Steering?
  5. scooper77515
    Actually, that engine looks GREAT as is...don't add anything to it :D (just kidding)
  6. Zooomzoomguy
    Zooomzoomguy Member
    Detroit, MI
    73 maverick, 2 door
    alternator and thats it.
  7. maverick1970
    Missouri
    In the 2nd picture mine is the same way nothing there.
    On the inserts for the heads they will have internal threads for accessories also.
  8. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    'Engine looks good...(y)
