Rear vent tip
Discussion in 'Technical' started by Thack, Sep 4, 2006.
  1. Thack
    Thack vision advicator
    Moreno Valley Ca
    For those in need of rear vent seals. I found that 82 honda civic has a rear vent seal that is very close to the mavericks. They are larger than the mavericks but, all you need to do is cut them to size and put the seam at the front lower corner. You will want to cut the ends at a 45 degree angle you can use a black silicon to seal the seam.
  2. Mercurycruizers
    Venetia, PA
    thanks for the tip...
  3. blugene
    Where is this vent?
  4. maverick75
    What he said^
    is it the one on top of the gas tank?or the filler pipe seal?:huh:
  5. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Good info,, Gene,, he is talking bout the rear pop out windows.
    Dan
  6. blugene
    :slap: Ok, thanks...
  7. maverick75
    What he said^...again:slap:
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Anyone know if these are repoped for the Civic kinda doubt they are available new.
  9. Thack
    Moreno Valley Ca
    Sorry I forgot I found them in the wrecking yard, much easier to find in good shape the Mavericks. Newer chevy car trunk seals look like they could work also, I used the Honda.
  10. Jamie Miles
    Alto, GA
    I've had a few
    Thanks for the tip!! The ones on my '69.5 just crumble away when you touch them or open the rear windows.
