'69.5 running! But one small problem...
Discussion in 'Technical' started by Jamie Miles, Sep 7, 2006.
  1. Jamie Miles
    Alto, GA
    I've had a few
    Well I went and pulled the 200/C4 out of Tim's (mtrhed) '71 Grabber yesterday. I brought it up to NC this morning and set it down in my '69.5. It's now up and running, runs awesome. :thumbs2: I'll make another post with pics and more info about the drivetrain later, it's pretty cool.
    The problem is the car won't start by the ignition switch in the car. You turn the key on, the radio and everything comes on, but when you turn it to start, nothing. You can take a screw driver and trip the starter solenoid and it will fire right up, and when you turn the key off in the car, it shuts the engine off, so that's working. But it will not turn over when you turn it to start. :confused: Anyone have any ideas? Keep in mind this is a '69.5 with the switch on the package tray, so the normal switch on the column stuff dosen't apply.
  2. Comick76
    Comick76 Grease Monkey
    San Angelo, TX
    76 Comet
    Neutral safty switch? I don't know about the early ones but my 76 has a 4 wire plug right at the firewall near the motor side of the master cyl. 2 of those are for the neutral start switch.(other 2 for reverse lamps) I always knocked that plug apart when I was changing engines.
  3. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    That's my guess.
    I'd also eliminate the solenoid itself. It's easy enough to swap out with one of the MANY that you have on hand.
    Good luck.
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    could be the switch itself. had one do that in a 67 mustang
  5. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    I agree. Sounds like the neutral safety switch, I think you know where that is located. When my safety switch went bad I was able to start the car by "jumping" the solenoid as well.
  6. blugene
    1. Try to wiggle the shifter as you hold the switch in cranking mode(apply the brake).
    2. Test light at the two locations. Solenoid from switch, switch to solenoid (in cranking mode).
  7. 69 ina 1/2
    This also worked for me until the switch went completely out:yup: .
  8. Jamie Miles
    Alto, GA
    I've had a few
    It was the neutral safety switch. I didn't even have the linkage and everything for the transmission in the car yet, and the shifter was just kind of hanging down in 2nd or 1st. :slap:
    Thanks!
