Remove Paint Front Door Vin Tags
Discussion in 'Cosmetic' started by rwbrooks50, Oct 8, 2006.
  1. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Any suggestions on removing paint from the tags? And still be able to read the tags.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    the paper tags in the door seal? or metal tags? prolly either way acetone or some sort of paint thinner....sand blaster is too rough...not sure if aircraft remover would help
  3. Craig Selvey
    I would try to VEEERRRYYY carefully scrape off paint with a blunt object...like a screwdriver. A razor might cut the decal. Paint stripper might eat it off.
  4. Jean Doll
    Palmerton, PA
    Paint stripper will destroy the paper sticker. Paint solvents can remove the lettering right off the sticker. I would do as Craig recommended and try to remove as much of the paint as possible with something with a semi-sharp edge. I have used dulled down razor blades and a very light touch to remove some of the paint from stickers. It can be nearly impossible to remove all the paint from a sticker, so I would try to remove just the paint from the numbers and letters that you need to read.
  5. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    I will try steel wool and/or a scraper. Thanks.
  6. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    Use a wire brush scraper edge. It came off the vin tag good. The tire tag smeared the letters a little. Thanks again.
  7. Craig Selvey
    Tire tags you can buy repops of from The Maverick Connection.
  8. Dave B
    Sometimes packing tape will pull the paint off the sticker.
  9. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    Good ideal Dave. I know I'll need it again on another car.
