Calling 351W owners with headers
Discussion in 'Technical' started by broncoisl, Feb 10, 2007.
What kind of headers / manifolds do you have in your 351W fitted car?
Poll closed Mar 12, 2007.
  1. I have headers that fit without modifications
    2 vote(s)
    28.6%
  2. I have headers that fit with modification of the header and/or the car body
    2 vote(s)
    28.6%
  3. I have headers that fit but don't know the manufacturer
    1 vote(s)
    14.3%
  4. I have manifolds
    2 vote(s)
    28.6%
  1. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    There is a lot of confusion about which headers if any fit our cars with a 351W swap. I thought I had seen a thread last year with pictures of the installation of Hooker 6901 in a car with the 351W, but now I can't find it.
    So hopefully this tread will clear things up a little bit.
    Owners of Maverick / Comet with 351 Windsor please vote and post information about your headers.
    Include:
    • Info about the car engine, trans, shifter type
    • Manufacturer
    • Model / part number
    • What modification had to be done to make them fit to the car and/or the headers
    Pictures / link to a thread about your installation would be great.
  2. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    My headers are old and falling apart, actually the pass side header seems to be unmodified, but the drivers side is severly modified (or repaired).
    Correction both headers are modified
    The car has a 351W, C4, Floor shifter, modified shock towers, stearing drop bracket.
    Manufacturer of headers unknown
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i have Hooker 6208 1 3/4 long tubes...
    Alot of work to make them fit...
    Must have floor shifter with these.
    The passenger side frame rail needs to be notched.
    The passenger side firewall needs a BFH.
    Driver side firewall needs a little hammering.
    The steering box needs a grinding to take off excess material.
    i have pictures ,ill see if i can upload any...
    Heres a link to the write up:)
    http://mmb.maverick.to/showthread.php?t=27516
  4. grbmaverickmo
    Aquashicola, PA
    71 Comet manual steer, factory floor shift no mods to car or header. They were tubular automotives 1 1/2 tube to 2 1/2 collector. That was about 18 or 19 yrs ago though. forget the part # but I ordred them over the phone direct from them for what I needed. Hope that helps
  5. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I have been using a set of Modified(bashed)Hooker 302 header(cause I had'em)..but will be installing a set of Crites headers around the end of the month. I will let you know how they work..but they look like they will fit quite well. Put some pics here: http://mmb.maverick.to/showthread.php?p=302193#post302193
  6. tim keck
    sharps chapel,Tn
    I had a '71 grabber,351w with early(probably 69-70)manifolds.They fit w/no mods to car or manifolds,but they sat right up against the upper control arm bolts.
  7. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    Took a picture with my passenger side header removed, seems to be a lot of space with the header removed.
  8. grbmaverickmo
    Aquashicola, PA
    Nice looking cut towers. They look nice all smoothed and painted
  9. 72Maverick351
    72Maverick351 Member
    Salem, NH
    1972 Maverick - 351w
    I have a 72 Maverick 2 dr, 1990 351w, C4 trans, Powermaster mini-starter. Hurst Quarter Stick shifter (cable operated). I used a set of Hedman 88660 long tube headers, 1 5/8 tubes to 3 inch collector. I removed the power steering and went manual.
    I was intent on not making any body modifications so almost every tube needed to be massaged at the first bend to give it clearance and not touch the body. The number 4 tube I cut and welded in a slight elbow that was cut out of a short tailpipe with the same diameter tubing, this was to allow for pitman arm clearance. It's very tight, putting in the header bolts an be tough the first time, but I've developed a method and it's not so difficult now.
    Hope this helps, good luck!
  10. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    Why is it that by looking at these photos I have the feeling that the new Doug Thurley shorties should fit in here.
    The photo on the left is a prototype of the Doug Thurley's on a 302, right is the 351W in my comet (it has 302 heads)
  11. Craig Selvey
    I think what is throwing you off is the fact that your shock towers have been cut back.
  12. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    Yes, maybe, but look at the location of the exhaust ports in relation to the cut.
    Could someone measure the width of the new headers? ,from the flange.
  13. Craig Selvey
    I don't think the problem arises near the exhaust ports.....but down lower where all the pipes try to exit "down".
  14. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
    I just figured out that my car has a BIG bell housing (164 tooth flex-plate). And am wondering how that affects the header issue. Bigger bell housing = less space for the headers.
    1. How about the rest of you 351W guys? is it big or is it small? :)
    2. Has anybody tried the hedman 88300 with a 351W?
  15. broncoisl
    broncoisl Member
    Iceland
    1974 Comet 351W
