Where is the VIN number on the inner fender?
Discussion in 'Technical' started by Farmall, May 20, 2007.
  1. Farmall
    Farmall Member
    New Mexico
    1972 Grabber & two 69.5 Mavericks
    Hello, in reading the posts on VIN numbers, dash removal, and buck body tags, there are references to the VIN number being stamped on the top of the drivers side inner fender. Is it under the outer fender mounting (bolt) flange? If so, is it forward of or rearward of the shock tower? Finally, can the inner fender be easily removed. Thanks for any help!
    Farmall in New Mexico
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I cant remember seeing a VIN on the inner fender, but cant say I ever really looked. The inner fender is spot welded and is integral to the entire front end, much like the radiator core support is.
    Dan
  3. Jean Doll
    Palmerton, PA
    On our 77' Maverick there is a Vin# stamped on the top of the drivers side inner fender in front of the shock tower. Here's a picture of some patches I welded in and in the lower right hand corner you can just see part of the Vin#.
  4. Mavaholic
    Its not really on the fender, its on the top of the drivers apron where the fender bolts to it.
  5. Dan Starnes
    West Central IL
    Now I know why I have never seen the VIN there, every car I have taken apart has been rusted there. I will look at my grabber next time I am out in my garage, I have it in pieces.
    Dan
  6. 71gold
    could be ...rusting...there because it is stamped into the metal as to leave a place for water to stand...:yup:
    ...:Handshake ...
  7. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    My buddies 75 had it on the passenger side apron under the fender ahead of the shock tower.
  8. ATOMonkey
    ATOMonkey Adam
    Plainfield, Indiana
    '69 & 1/2 Maverick
    Yep, it's on both sides. With any luck it hasn't rusted away. If one side can't be read, you can try the other.
  9. Farmall
    Farmall Member
    New Mexico
    Thanks guys! The information was very helpful!
    Thanks for all your help, it is much appreciated. Farmall
