only 3 more needed
Discussion in 'General Maverick/Comet' started by JHodges, Jun 1, 2007.
  1. JHodges
    JHodges thumper
    Dora Alabama
    Now I only got to get a 69.5, 76 and 77 Maverick to have one of every year
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Technically you only need 2 as the 69.5 was titled as a 70
  3. JHodges
    JHodges thumper
    Dora Alabama
    how can you tell the difference between a 69.5 and a 70
  4. chandler
    chandler Member
    Warrenton Mo
    Maverick
    The key is on the tray instead of on the column
  5. JHodges
    JHodges thumper
    Dora Alabama
    then technically my 1970 is a 69.5. I thought all 1970 models had the key on the tray and that the key was put on the column in 1971
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Pretty cool,, you may the first to arrive at an all year collection.
    Dan
  7. don graham
    good luck. i don't have any more room. 4 is enough.:)
  8. stmanser
    Davenport, Iowa
    i need mor, but i have no room for the 3 cars i do have right now and the car the my g/f has
  9. maverick75
    yeah i've missed alot for good deals for not having any room
    in my front yard we have
    Dads
    70s chebby van SB...POS
    91 maxima w/93 3.0 V6...POS
    93 plymouth grand caravan 3.0(daily driver)
    86 chebby surburvan/silverado 6.0 AT(its at his friends lot)
    Mine
    75 mav 302
    Uncle #1
    89 F250 460 AT(daily driver/beater/work truck/fast as hell)
    Uncle #2
    80s nissan sentra4CYL...POS
    Uncle #3
    94 honda accord4CYL(daily driver...POS)
    Sisters
    82 mercedes 240D(future turbo project,if she lets me)
  10. cookc
    cookc Member
    Indianapolis Indaina
    1976 ford maverick 4 dr. straight 6.
    cool do you have a pic?
  11. Jamie Miles
    Alto, GA
    I've had a few
    Technically, a '69.5 Maverick does not exist, Ford never made a '69 model year Maverick. it is just a term someone came up with to identify between the early '70 model year cars (built in the spring and summer of 1969) and the later '70 cars. '69.5 Mavericks have the ignition switch on the package tray next to the radio, a smaller diamater steering column that resembles a '69 Mustang column (and uses a '69 Mustang turn signal switch), a steering wheel that has a chrome horn "ring" on it instead of just a horn button, smaller 9 inch front drum brakes from the Falcon with '69.5 only brake lines that are no longer available, and the package tray itself was diffrent in 69.5's from the later cars (it has a extra piece riveted to the top of it and is beefed up where the ignition switch mounts. '69.5 Mavericks do not have a sticker inside the door jamb like all other Mavericks, instead they have a metal tag riveted to the door. '69.5's also have a diffrent style of throttle cable which has a mechanical linnkage on the end.
    Here are some pics of my '69.5. My car does not have the original steering wheel or front seat. Everything else is original. My particular car was buck tagged on July 15, 1969, and the door tag has a date code of July 17, 1969. I have since used the car for parts after discovering it had been rearended and side swiped bad enough to do structural damage.
  12. Jamie Miles
    Alto, GA
    I've had a few
    Here are a few more pics, of the diffrent throttle cable and also the front valance (I converted the car to the later style cable during the few months that I drove it daily). From what I have seen, '69.5 Mavericks have a larger lip at the bottom of the opening then '70-'72 Mavericks.
  13. stephen
    stephen jet mechanic
    Albuquerque, NM
    69.5 Maverick
    My 69.5 didn't have that mechanical linkage on it nor does it have the rivited area on the dash tray, but it is factory a/c car
