Shackel bushing size?
Discussion in 'Technical' started by Beerstoreguy, Jun 4, 2007.
  1. Beerstoreguy
    Beerstoreguy Member
    St.Petersburg Florida
    1973 Comet
    I just recived my JC Whitney leaf springs and the rear bushings are too small 15/16 for the 1 1/8 spring eye.
    Where can I get the correct bushings,do mustang bushings fit? Also where can I get solid aluminum front bushings for a" bellcrank style" traction device?
  2. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
  3. Mavaholic
    My JCW 4 leafs also had larger than stock rear spring eyes. I know the early Mustang are larger so I bought a set at Carlisle a few days ago. I hope to put them in this coming weekend. I will let you know.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Hmmm ... has JCWhitney started shipping Mustang leaf springs to fill Maverick orders? I know the springs I bought last year from JCW used the correct Maverick bushings ...
  5. scooper77515
    My JCW springs were a direct swap, except 4 leaf rather than 3....:hmmm:
    Autokrafters bushings were perfect...I also bought stock shackles.
  6. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    My bushings were too small for the JCW springs also. Just installed them anyway. So I should get the mustang bushings.
  7. Beerstoreguy
    Beerstoreguy Member
    1973 Comet
    The stock bushings just seem to be verry sloppy and I want a good tight fit to prevent wheele hop and excess body roll. If i need to I will get someone to fab solid aluminum,I will. Or find some 1 1/2" poly and turn them down for a tight fit. Am I being too critical here? or is that kind of sloppy fit normal? I want to do it rite the FIRST time!
  8. Rando76
    Rando76 Member
    Claremore, OK
    Yes, JCWhitney is shipping the springs, but they are not Mustang springs. I guess I should say that John R Spring is drop-shipping the springs. Anyway, I just got mine and I have the same problem. The bushings seem too small and are a little sloppy. I may need to order a different size too.
  9. Mavaholic
    I dont think your being too critical. I also installed the stock bushing and they were real loose. I had totally forgotten about them and at last years Roundup, I had major wheel hop problems. I had never had this problem before so I'm hoping it was the bushings.
  10. Mavaholic
    OK, I just went out and pulled my shackles out. The Mustang ones I bought was too big. They were 1 5/16" with a 9/16" hole. I measured my springs at 1 1/8" with a 1/2" hole. Guess I'll keep looking.
  11. Dave B
    I have some on back order from Auto Krafters, shouldn't be too long (I hope)
  12. Mavaholic
    More bad news. I talked to ESPO and they said there are no cars that use a 1 1/8" bushing with a 1/2" hole. They do have 2 bushing listed with 1 1/8" but the holes are 5/8" or 3/4" Anyone else have any ideas?
  13. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Use bigger bolts and drill out the shackles? I just measured my JCW springs I got last year and the hole is just a few thousandths over 1". That's the correct size eyelet not the oversize one right?
  14. Mavaholic
    My eyelets are a hair under 1 1/8". If nobody comes up with a bushing, I will probably get the 1 1/8" with the 3/4" hole. Then have a machine shop make me 1/2" to 3/4" bushings out of aluminum or something.
  15. Rando76
    Rando76 Member
    Claremore, OK
    That's a good idea. I wonder if somewhere like Fastenal would already have a bushing like this.
