While I'm waiting for the engine to come back from the machine shop, I'm thinking about cutting the shock towers. The engine is a 302, but since it is a drag car I'm beginning to think extra header and sparkplug clearance will be beneficial. Anyone have a template to use to cut them?
I'm thinking I should cut them also. Does anyone have the dimensions of the cut? Mustang II, maybe next year.
Do a search, I did mine a little deeper than others. An advanced search with threads started by me will get you dimensions. If you cannot find them, PM me and i will pull them up for you. I highly recommend that EVERYONE do shock tower cuts unless they are trying to keep the car 100% stock looking. It makes all the difference in the world when swapping plugs, putting on headers, pretty much any work under the hood has more room. I remember the first time I swapped plugs...took me over an hour to get the 4 rear plugs out. My dad and I were thinking of modifying the towers at that point. A year or so later, I joined the forum and got the directions from here.
