Pictures of cowl repair
Discussion in 'Technical' started by bmcdaniel, Oct 11, 2007.
  1. bmcdaniel
    Came across some pictures I took last year when I opened up my cowl due to a water leak. Thought some of you might want to see how it looks when you just cut open the end of the cowl that is normally hidden under the fender. Ends up that's not where the leak was but while I was in there I slopped some POR 15 around to seal it up. Should be good for another 37 years.
  2. MikeG747
    MikeG747 Member
    Arkansas
    Good pics! (y) Do you have any of the repair?
  3. mav1970
    I've seen a lot of the cowls repaired by removing the entire cowl cover or cutting through the nice painted surface at the vents but I like this way better.
    Heck, you could completely screw it up and the fenders would still cover it up. :dancing:
  4. lastchance
    lastchance Member
    Hingham , Massachusetts
    Where was the leak?
  5. bmcdaniel
    Not sure yet, maybe at the "A" pilar. I'll dive into that this winter and post what I find.
  6. bmcdaniel
    Nope, sorry.
  7. rayzorsharp
    Years ago I used to have a Mustang Restoration shop. I repaired many cowls by cutting into the side like that. (y)
