#1 |
I <3 Boost
Vehicle(s): 74 2door - Small bumpers, 5.0 EFI, Tremec 3550, disc brake 8.8,MII front end, boostediTrader: 2 (100%)
head bolt q
i've got a 6cyl. and was wondering how the 16th head bolt is. on one mav its like a double ended bolt and i can't figure it out for the other mav. the bolt of whatever was already out and i have two brackets that i think one goes to the a/c.what are the dimensions for the bolt and does autozone have them?
| Sponsored Links |
#2 |
Seth
I'm not much on 6 bangers, but...
Is this under the valve cover or do you even know that?
If not, is it a groundstrap mounting stud as well as a head bolt? Check that and see, I'll look in my Chilton's if I get a chance. Seth
__________________
#3 |
I <3 Boost
its not under the valve cover. and its the closest bolt to the front. i think that there is a bracket to the a/c compressor that goes on the top part.
#4 |
Indiana State Rep - MCCI
You are correct Will...it is an AC bracket hook-up location.
Interested in this thread? Receive email updates and post your own response by registering today, it's free! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 4 bolt to 5 bolt hubs | wulfhinzdenzin | Parts Interchange | 6 | 2009-12-18 07:23 |
| converter bolt pattern | rolandag2 | Technical | 5 | 2006-12-21 18:36 |
| question FEL-PRO Head Gaskets | Acornridgeman | Technical | 6 | 2005-07-12 21:01 |
| head bolt sequence? | Russ | Technical | 6 | 2005-05-23 10:12 |
| Bad head gasket. 250 What to do? | Russ | Technical | 8 | 2005-05-15 16:43 |
