subframe conectors & traction bars
Discussion in 'Parts Interchange' started by nastynickel, Apr 8, 2008.
  1. nastynickel
    nastynickel gearhead car junkie
    Portorchard, WA
    1972 grabber mav
    I need a set of subframe conectors and traction bars for my 72 mav but cant find any listings. Any sugestions?
  2. fredee
    fredee Member
    South MS.
    1971 comet
  3. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Interesting.
    Dan
  4. scooper77515
    mysticcobra, the ebayer on that link, is a member here. His forum username is not mysticcobra, though. I think it is Yellow75.
    He likely got those from Rudy Bidlack. He is a member here user name Bulhead. His phone number can be obtained from the classified section of the MCCI quarterly. I just recycled all of mine or I would help out.
  5. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    If I'm not mistaken, those look like Dan Starnes' connectors. I believe Rudy's are rectangular.
    -Corbin
  6. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Those look like they'll go under the floorpans without any cutting, still require welding though... (y)
    Russ
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Those are Dan Starnes Manufacturing ;) connectors and the seller is mysticcobra96/Yellow75/Mike Harrison.
  8. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    Chassis Engineering for sub frame connectors
  9. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    +1 here for CE SFC
    and traction bars...CALTRACS !!!!
  10. scooper77515
    I agree, CalTracs for traction bars. I was not aware that Dan had the round subframe connectors and Rudy had the square ones. I thought it was the other way around. I stand corrected.
    The round ones fit really nice, and no lower than the exhaust and CalTracs when installed, but you will need to weld them up.
    Here is what mine looked like right after I replaced the exhaust. They fit nice and tight up to the frame. I have not painted them yet. Still waiting for a light coat of rust so the POR-15 will stick to them. They stiffen the ride a bit, and I hear you can jack up at that point, even though I have not tried it yet...
    EDIT--The subframe connectors in this pic are NOT those available from other members, but are based on the same design.
  11. yellow75
    Tillamook Oregon
    Yes I am the seller of the subframe connectors on ebay and they are the infamous Starnes bars. Just thought someone else could use them, nice quality and proven fitment.
  12. Earl Branham
    Lugoff, SC
    I have the Starnes Bars on my car....love'em!
  13. don graham
    I have the cal tracs on mine. They also make a single leaf spring set up.:)
  14. eddie1975
    Martinsburg, WV
    sold
    they sure do...killercomet has them on his car pulling 1.6x 60fts:yup:
    oh and i pretty sure that 1974cometGT(stephen m) has them and i think most of us has seen those wheelies:D:bowdown:
    must be pretty good stuff
  15. jtcomet
    jtcomet Member
    Mckinleyville California
    74 Maverick 302 ,70 Grabber, 69 Mustang Fastback, 05 Mustang V6, 04 Mach 1, 92 T-Bird V8, 77 Ford F-250, 64 Comet AFX replica
    Cal tracs
    quote=don graham;441749]I have the cal tracs on mine. They also make a single leaf spring set up.:)[/quote]
    I run cal tracs on my wife's 69 Mustang and my 64 Comet. Was doing 1.43's 60' with big motor:thumbs2:, until it blew. Now doing 1.52's 60' with little
    motor and running calverts single mono spring, might have to invest for
    the V8 Mav someday.:drive:
