Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2003-10-22, 09:56   #1
Scotty P
Member
Scotty P's Avatar
Vehicle(s): 1970 Maverick
U-Joints
I am installing my new Locker rear end and gears this weekend( sorry, a bit excited!) and was wondering what are you Mavs running for U-Joints? Anything aftermarket or just stock? I am putting in 4.11's with the ocker and drag radials(275) so I may finnaly get a LITTLE traction. With a 3000rpm stall I was wondering if the stock U-joints are adequate. Thanks Scott
__________________
Scott 1970 Maverick
1968 302, Edelbrock Perf RPMs, Race Demon 650 cfm, Weiand accelerator, Comp Cam 282s, TCI C-4, 3000 stall, 8" w/powertrak locker 4.11, hedmans and 40 series flows
Scotty P is offline   Reply With Quote
Sponsored Links
Old 2003-10-22, 23:09   #2
Scotty P
Member
Scotty P's Avatar
nobody have an opinion? Scott
__________________
Scott 1970 Maverick
Old 2003-10-23, 04:42   #3
Mavaholic
Growing older but not up!
Mavaholic's Avatar
Vehicle(s): Original 72 Sprint Owner, 71 Comet GT, 69.5 Mav convertible project, 57 Ranchwagon
Images: 20
I dont know whats in mine. When I had my driveshaft made I told the guy to make sure it would be good for 450hp knowing i would only be running around 300.
__________________
My Comet GT Build
"Todays racing technology has diminished the role of the driver way too much. Back in the days of 4 speeds, the driver had a lot more to do with the outcome of the race, and I can't imagine anything being more fun than that." Ronnie Sox
Mavaholic is offline   Reply With Quote
Old 2003-10-23, 21:10   #4
CometGT1974
Gearhead
CometGT1974's Avatar
Vehicle(s): 74 Comet GT
Images: 9
A good heavy duty Spicer ujoint will do the job....the strength is in the size....the 1350 is a common size on high horsepower drag cars....I think stock is like a 1310 or 1330......ideally as you step up in horsepower you should probably step up in size. My alulminum driveshaft came with 1330's I think, but I ended up using a 1330 to 1350 crossjoint in the rear because of the chromoly 1350 rear end yoke.
__________________
74' Comet GT / 440" stroker
SFI 25.5 Chromoly Cage
Best E.T. to date: 5.50 @ 130mph
____________________________
Famous Quotes: "That's not a maverick anymore, it's a rocket ship."
CometGT1974 is offline   Reply With Quote
Old 2003-10-23, 23:13   #5
Scotty P
Member
Scotty P's Avatar
tHANKS gt
__________________
Scott 1970 Maverick
Old 2003-10-24, 06:58   #6
Lightning
Member
Vehicle(s): 1971 comet GT
Yea . Spicers are pretty much the norm in drag racing .
Lightning is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Ball Joints & Alignment? Maxx Levell Technical 9 2005-05-17 06:24
Removing U joints to pull tranny Halebopp Technical 12 2005-04-22 10:16
ball joints teslajc Technical 13 2004-12-14 04:57
Upper ball joints Comet-73 Technical 16 2004-05-20 18:06
drive shaft and U joints its_not_safe Technical 3 2004-04-29 15:55
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
