Plug on the brake pedal
Discussion in 'Technical' started by streetrod77, Sep 27, 2008.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    What is this and what does it do? Do I need this or is there away aound using it? I have changed my power brakes to manuel and I dont know what to do with this plug. The way I changed my brakes, I forgot about this piece.
  2. 71gold
    that's the brake light switch...
    ...:Handshake...
  3. Bob Wiken
    Fayetteville, Arkansas
    I'd suggest finding a way to reinstall it. You definitely need it
  4. 71gold
    only if he wants people to know he's stopping...:huh:
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Frank, your so funny.
    How does it work? I took it off so long ago, does it matter what direction it's install?
  6. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Nice garage too Frank. I just looked at you pics.
  7. 72MAVGRABHER
    Roanoke, Va.
    When you depress the pedal it activates the spring/switch, and current goes to your lights, you'll need it for general safety and so insurance would pay out if someone rearends you, if you have inspections in Tenn. You'll need it to pass, and as an all around GOOD IDEA, i'd put it back on.
    Why'd you go to manual from power if you dont mind me asking?
  8. 71gold
    ...it will fit 2 ways...one right...one wrong....how do i know...:rolleyes:
    ...and a PITA to install...for me....
    i think someone posted some...install pics.
    ...Frank...:Handshake
  9. CaptainComet
    Frank,
    If you think they are a PITA to install on your car ... you ought to try it on one with a clutch pedal ...
    Here's the drill ... You can ...
    A) Look at it
    B) Touch it
    C) Grab it with a tool ...
    but you can't combine any two of the above :mad:
    Of course, the one in my white car went out three times in the six years I had it!
    If I ever had to do that again in a stick Comet, I'd remove the clutch pedal first.
  10. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I went to a 5 speed and the booster was in the way to get the cable inline with the clutch pedal.
    I love this forum. Do anyone ever sleep...lol
  11. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I see how it works but is it connected to a bracket or do someone have a pic with it on the pedal?
  12. 71gold
    you have to...take the seats out, remove the carpet, drop steering column, remove the dash and windshield...
    before you can see where it's mounted...:yup:
    maybe not the carpet, dash, windshield or dropping the column but the seats out is a maybe...:hmmm:
    ...TFF...:D
  13. rthomas771
    To install the switch, position the switch, pushrod, bushing and washer on the brake pedal pin and press the hairpin retainer into place.
    connect the wires at the connector.
  14. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks Jeff, I saved it so I can print it out for a refrence. I can't find the washer though. You thinks it's that important?
  15. rthomas771
    The way I look at it...Ford bought a bunch of washers and paid someone to put them on the car. The book says they were nylon washer but I'm sure any washer as long as it fits will be ok to keep the switch from flopping around will be fine.
