I need T5 tranny install Info
Discussion in 'General Maverick/Comet' started by Jimmy2gates, Dec 16, 2008.
  1. Jimmy2gates
    Jimmy2gates Member
    71 mav
    OK ,folks i just got a hellava deal on a 1994 T5 tranny with a new clutch ,pressure plate, throw out bearing still in box and fly wheel;,also got the mustang aluminum drive shaft, transmission cross member that bolts to tranny plus the cross member for the dual exhust all for 300.00 bucks ,i think this was a good deal.All i need now is a member here to link me to a thread with all the info and parts i will need to put this into my Black 69.5 grabber clone street car ,the same one im putting the mustang 11 cobra rack in pinion steering in . This should be a pimp ride when its done ,It would really be great if someone here has done this and has pics to go with it to walk me through the transplant ,cheers James ,and yes im pretty good at fabricating. Thanks for any help :thumbs2:
  2. Earl Branham
    Lugoff, SC
    Jimmy; you are going to need a crossmember to make it work. I had Frank (71gold) to help me with his friend and shop owner, to make one custom. You might talk to him, and maybe we can get my car to make a template. Ain't cheap, but it is the best piece I have seen in a long time. BTW, pay special attention to the pinion angle. If you get it too straight, it will eat rear u-joints...ask me how I know. Good luck!
  3. mean_maverick
  4. 71gold
    you're going to...dis-respect...a 69.5 mav?:huh:
    from doing a search on the board:
    it looks like they only made them 1 year...
    ...:cry:...
  5. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    The 94 95 transmissions are longer than the fox cars.
  6. mean_maverick
    yup, had to shorten my drivehaft 1.25" when i done my swap
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The input shaft is longer on the 94-95 T5. You will need the correct bell housing from that year. This was done to place the shifter correctly in the SN95 Mustang. This may impact your crossmember and driveshaft needs.
  8. mean_maverick
    it did for me. as mentioned, my driveshaft was cut down 1.25" and the transmission crossmember had to be extended down about 2" and moved back about 1.5". but i already had this transmission available so i went ahead and used it. this spring when i change engines, im going to build a better looking crossmember for my car and im going to keep progress pictures of it but would help people using the 94-95 trannies the most.
  9. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    :rofl2: so was my 72 LDO.....during 1972
  10. mavron 70
    mavron 70 Member
    R.I.
    1970 maverick 5.0 t 5 trans 59 ford rear with 4.11 cogs
    jimmy, you will also have to notch the floorpan support above the trans. Earl had a good pic of this when he did his car and of the crossmember. maybe he still has them?? The mustang sites are helpful on this swap too. It's a great thing , but you dont want to go too low on the rear gears, as first gear becomes useless . I have 4.11's in my car and first gear is pretty much a waste of time . I can cruise around on country roads in 5th gear all day though:) good luck
  11. Mavaholic
    Here is what I had to do to my tunnel to make it fit. Look at post #79
    http://mmb.maverick.to/showthread.php?t=36382&page=8
    Your tunnel is even smaller but I know Barry runs a T5 in his 70 so it will fit. As far as a cross member, I was able to modify my stock one to work just by notching the center front edge and elongating the holes to slide it forward enough to bolt up. I'm using one of those adapter plates so I will retain my stock mechanical linkage.
  12. mean_maverick
    but ur running a 87-93 T5 correct?
  13. Jamie Miles
    Alto, GA
    I've had a few
    I think in order to use one of those adapter plates, you have to run the '94-'95 input shaft?
    The input shafts are extremely easy to change on T5's. If you have the parts on hand, it literally takes less then 20 minutes to convert a '94/'95 T5 to an '87-'93 style, or vice versa.
  14. Mavaholic
    I am using a 93 Cobra R trans. The input shaft is about 9/16" longer than the stock trans. The adapter plate is the same thickness which makes it all work.
  15. mean_maverick
    here's what i had to do to my trans crossmember to make my '94 transmission work. like i said before, it doesnt look pretty but serves the purpose. that's why i plan to build a 'nicer' one this spring when i tear my car apart again
