| Sponsored Links |
#3 |
Senior Member
Not a dumb question. Just ask if you don't know. A lot of times people will just call it a flywheel, even if it's an automatic. So it's good to ask.
__________________
don graham q751
#4 |
Certifiable
the visual difference(just for reference) the flex plate is fairly thin except for the starter ring gear. a fly wheel is really thick, due to the surface for the clutch..
__________________
"@#%$ holding on...Start Praying!" I'm not a sheep, grab life by these horns! 71 mav Grabber 74 Comet 73 F250 High Boy 83 honda magna v65 06 subaru outback sport |
#6 |
the road warrior
Flywheel is usually either cast or billet, noticeably thicker and heavier, and will have a large smooth surface for the friction disc of the clutch to make contact with. A flexplate is usually just stamped steel with the starter gear welded to it, as was said, the flexplate is used in automatic cars and is basically just a way to connect the torque converter to the crankshaft.
Interested in this thread? Receive email updates and post your own response by registering today, it's free! |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
