Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2009-02-19, 22:20   #1
mashori
Member
Vehicle(s): 1971 V8 Maverick
heater control valve stuck
My heater won't work on my 71 mav, A/C works great and all the other functions are fine on the control panel. I checked my heater control valve and noticed it was kinda stuck so I turned on the heater and manually pushed down the lever on the control valve and the heater worked great.
Do I need to change the control valve? Is there a cheaper one than this $70 piece?
Also, is it hard to change? Because it looks like I'd have to drain the coolant.
__________________
Silver State Classic 9/2011 - 7th place 105.3550mph
Silver State Classic 9/2012 - 7th place 124.9101mph
Fontana 1/4mi 6/2011 - 12.5sec 115.9mph
mashori is offline   Reply With Quote
Sponsored Links
Old 2009-02-19, 22:23   #2
Mavman72
I'm mister heat mizer...
Mavman72's Avatar
Vehicle(s): 1972 Maverick 2 door.Original V-8 3 spd std shift.Also a 72 one owner Sprint sporting a 351 Windsor
Images: 29
Pinch off the hoses then remove the old one.(minimal coolant loss that way)post an add on the forum...betcha someone has a good one to sell.Or go junk yarding.Should be able to find one in any ford/lincoln/merc with A/C of the era,just gotta hope you find a good one.
Mavman72 is offline   Reply With Quote
Old 2009-02-19, 22:26   #3
mashori
Member
So nothing wrong with my vacuum lines right? Any way I can test it? I am gonna go looking for one anyway though.
what about this one, can I use this one instead? http://shop.oreillyauto.com/ProductD...rtNumber=74612
__________________
Old 2009-02-19, 22:36   #4
71gold
Frank Cooper
71gold's Avatar
Vehicle(s): '73 Grabber
Images: 45
what you need to know is what valve it is...norm open/closed... these valves work both ways.
my valve will close when i start the car...when i turn the heater on, it opens...
you are on the right track to find one. i have a black plastic one on my Mav.
...Frank...
71gold is online now   Reply With Quote
Old 2009-02-19, 22:38   #5
71gold
Frank Cooper
71gold's Avatar
Images: 45
to check...start the car, there should be vac. on the hose. turn the heater on..no vac.
Old 2009-02-19, 22:44   #6
71gold
Frank Cooper
71gold's Avatar
Images: 45
you may want to flush the heater core while you're at it. just take both heater hoses off at the engine. run water through one hose and then the other. do this untill the water is clear. change the valve and all you have lost is the coolant in the heater core.
Old 2009-02-19, 22:44   #7
mashori
Member
nice! that sounds simple. got it . . . and sweet idea about pinching the hoses, so simple but saves me a lot of time.
__________________
Old 2009-02-22, 10:11   #8
mashori
Member
Could I purchase this one instead? I see it on the parts list of the 1976 cars. Does it have the vacuum regulator on it as well? This is thing is like $12!
__________________
Old 2009-02-22, 10:25   #9
71gold
Frank Cooper
71gold's Avatar
Images: 45
i would say...YES...make sure the valve is closed w/vac. on. (5/8"x5/8")
Old 2009-02-22, 11:43   #10
mashori
Member
Oh good! my local Kragen in santa monica has it so I'll pick it up.
__________________
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
