Maverick Rotisserie?
Discussion in 'Technical' started by BIGbully, Nov 30, 2003.
  1. BIGbully
    BIGbully Maverick Maniac
    Omaha, Ne
    Has anyone built a rotisserie (360degree stand) to turn their maverick all around while working on it? If so does anyone have plans to follow? Front and rear bumper mounting would probably be about the only way to do it, unless someone has a better idea to share. Thanks guys.
  2. Mavaholic
  3. wardf
    wardf Ward Frahler
    Elizabethtown, Ky.
    70 maverick
    dennis, did you buy the bottoms up jr? what does a stripped mav weigh? and what did you do for mounting, did it come with something for a mustang or did you have to fab something up?
  4. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    i called them at one time and asked about a set up for a maverick and they do have one but not too sure where it mounts bu tthey recommended door braces for sure
  5. Mavaholic
    I bought the JR with the hard casters along with the unibody bracket kit. Worked great. I had to drill a hole through my front frame rails to mount the front. The rear I mounted in the bumper mount holes. I dont know what the shell weighs but it I'd bet it's around 1200 lbs or less. You dont need any door braces.
  6. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    dunno was just going by what they told me :D
