Drip rail removal tool
Discussion in 'Cosmetic' started by blugene, Mar 31, 2009.
  1. blugene
    Drip rail trim removal tool
    I used this and no bends or dents.
  2. mav1970
    Nice simple use of a piece of heater hose. (y)
    I removed mine intact but didn't have a tool to make my life any easier.
  3. Rando76
    Rando76 Member
    Claremore, OK
    Are you talking about drip rail TRIM?
  4. Bob Wiken
    Fayetteville, Arkansas
    I used a bottle opener (Church key). it worked fairly well
  5. krelboyne
    krelboyne Remember
    Salem, Oregon
    That is what I use too, a little electrical tape wrapped around it and viola.
  6. Rando76
    Rando76 Member
    Claremore, OK
    I guess I need to see this in action. The last time I removed drip rail trim, it didn't go so well.
  7. Earl Branham
    Lugoff, SC
    I removed mine to have the car painted. Liked it so well without the trim that I never put it back on.
  8. mav1970
    If you have the window down a bit, does rain come in on you without the drip rails?
  9. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    I believe they are referring to the chrome trim on the drip rail. Not actually removing the drip rail completely.
  10. blugene
    You are correct.
  11. blugene
    Well, I want to put mine back on. Only thing is, the powder coater guy who was cleaning them for me lost them. :(
  12. pil1sbury
    pil1sbury MavBoy living life
    Virginia
    1974 FORD MAVERICK
    I found a new way to get the drip rail trim off easy instead of the church key. If you get a pair of Channel lock pliers and put electrical tape on the grab part lay the tape on thick so the groves won't scratch. Then you grip the trim and twist up slowly so you won't bend or scratch the trim
  13. simple man
    simple man Member
    Bunnell,Florida
    I never had too much of an issue getting it off, it is getting it back on! No matter what I do the paint wants to chip off while installing it.:cry:
  14. 55crownvic
    55crownvic Member
    colorado springs
    Too late now, but when getting the car painted its best to sand the drip rails down to the metal right before painting, that way there is less material for the trim to try and go over.:yup:
  15. mav1970
    That thought crossed my mind too so I decided just to not re-install them. I had no choice about removing the pieces as I had corrosion issues under the trim :)
