Found a sending unit that swaps in with little mods
Discussion in 'Parts Interchange' started by Joe Dirt, Apr 1, 2009.
  1. Joe Dirt
    Found a fuel sending unit that swaps in with little mods
    On my 74 (dont know which one are the same)
    Ordered a 65-68 mustang fuel sending unit from mustangs unlimited seen here to harvest the parts to fix mine but I didnt have to:huh:Thought it was a good deal compared to the others that swap as far as money wise
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=120394934812
    Uses the same gasket (rubber seal)same diameter and shape inside the tank and at the sealing surface. I did have to modify the electrical plug (cut the factory one off and replaced with a eyelet) and re grounded the other wire to the tank body.The only big thing I noticed (which worked good for me) is the fuel outlet is facing rearward (longer fuel line should solve that for stock guys)
    Just wanted to share hope it helps someone like it did me.
  2. nickmav70
    nickmav70 Nick Maverick
    Dallas, GA
    1971 Ford Maverick
    thanks for the tip... i will order one for my 70 and let everyone know how it turns out
  3. mean_maverick
    ive always wondered how one would fit. thanks for the insight!
  4. rayzorsharp
    Let us know what kind of readings you get from top to bottom. (y)
  5. Joe Dirt
    I ran it through the paces before i installed it then checked it as i put fuel in it (5 gal can at a time were i drained the almost full tank it had,Seems to be as accurate as the other was except this one works all the time:rofl2:
  6. mean_maverick
    does it have the same bend in it so that it will feed from the bottom of the tank?
  7. Joe Dirt
    exactly the same as the factory one,I would had took pics but forgot my camera
