Anyone know...
Discussion in 'Technical' started by Jamie Miles, May 17, 2009.
  1. Jamie Miles
    Alto, GA
    I've had a few
    Anything about a Rochester BC carb? I acquired one yesterday afternoon from an interesting old '63 Chevy Bel Air that's flipped over hanging off a cliff out in the middle of some woods (that's a story in itself). That car had a big straight 6 in it, I think a 235?
    This thing has a massive air horn compared to the Carter RBS I'm running now. It drops right on a 200 perfectly. I spent a few hours last night going through it, cleaning it and putting in a rebuild kit. Going to stick it on the Mav tomorrow and see what it does...
    If it actually works, it's going to be hilarious. It needed a good bit of cleaning, and pretty much everything on it was seized up, but it did sit in the woods for 30+ years. All in all it is the easiest carb I've ever rebuilt. Replaced all gaskets, needle and seat, accelerator pump and some check balls and springs. Float and everything was in great shape. Pics below of where I got it from... yes, that's where I found it, sitting right there on that intake manifold. :rofl2: It took 45 minutes just to get the hood open...
  2. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    good luck! hope fully it works.... by the time your maverick is done it will be a chevy:biglaugh: ......... almost........ J/K.
  3. rmmpe
    rmmpe Member
    Milford, PA
    1933 REO Roadster
    That lends new meaning to the expression "Built Ford tough with Chevy stuff".
  4. Jamie Miles
    Alto, GA
    I've had a few
    Not only does it run, it runs great!! No tuning or anything yet, I just slapped it on, primed the bowl, hit the key and it just fired right up and sit there and idled perfect. Throttle response is practically instant with no hesitation, popping, cracking or anything.. Just got to get the throttle cable hooked up some how and I can take it for drive. A factory Maverick Carter YF air cleaner base will even drop right on with a couple of small easy mods. If it runs as good down the road as it sounds sitting my driveway, it's staying on there.
  5. Joe Dirt
    car looks like it may have some parts worth going back and getting
  6. Jamie Miles
    Alto, GA
    I've had a few
    Quite a few actually. The body itself isn't even really that bad. That rear bumper still looks practically new. It's got a 235 with a powerglide behind it. I'd love to get the whole thing out of there, but the only problem is it's about a mile back into some woods, up and down some pretty ridiculous hills. How it got there is beyond me. The first time we found the car was back in the early 90's, and it had already been there for a long time back then.
  7. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I remember you telling me about that car when you were up here I think. I would love to hear the story of how it got there. I bet money alcohol was involved somewhere in there. lol
    Sounds like it was an easy rebuild and it sounds like it's going to run good as well.
    I am still in a mental struggle rather I am going to try and get this 200 in my 72 running or just go straight to a 302. It is real complete and free spinning but the throttle shaft is stuck solid. I guess I need to pull the carb, tear it down and soak it.
    Good luck with it
    clint
  8. Jamie Miles
    Alto, GA
    I've had a few
    Yea, I would love to know how it got there as well. As for stuck throttle shafts, every moving part of this carb was seized tight this time yesterday. I soaked it all with Marvel Mystery Oil and let it sit about 15 minutes. Then just started tapping around on it with a screw driver handle and got it all moving again. PB Blaster would probably work even better, but the Marvel Oil was just what was near at the time.
  9. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    hey clint i have a new carb for a 200ci ill let it go for $60 to your house
    brad:)
  10. Jamie Miles
    Alto, GA
    I've had a few
    Or rebuild the one you have for 12 bucks.. Or ship it to me and I'll rebuild and test run it prior to shipping it back for $30...
    Got about 50 miles on the Rochester today. Runs real good, just a little rich. Need to step the main jet down some
  11. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    NEAT! There is some sort of 40s era car next to my daughters school on it's side. Really makes you wonder why it's on it's side...who just leaves a car?
  12. Jamie Miles
    Alto, GA
    I've had a few
    Seems like no one knows anything about this carb, what CFM or anything. Even posted on fordsix and haven't got any response. Played with the timing some today and swapped the main jet out of an old Carter YF into it. From a dead stop with the car at idle, there is a slight stumble if you mat the gas, but otherwise just normal driving around town and interstate driving it runs great. It has a heck of a lot more low end torque, it'll do the one wheel peel all day long. :burnout: :rofl2: The stumble seems to be going away the more I drive it. It still smells like it's running rich, but the gas mileage seems to be great so far. Definitely an improvement in gas mileage around town. Just seems strange still after all those years having something like this that came off that Bel Air on my car. If I didn't pull it and rebuild it myself, I don't think I'd believe that's where it came from.
  13. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    http://www.carburetorfactory.com/expvw21.html
    It is for the most part just a Rochester B series carburetor the differentiation between the two is the thermostatic choke that came standard on the BC series carburetors
    Here is an arcticle I found on a rebuild of the BC series carbs
    http://www.classictrucks.com/tech/0802ct_rochester_carburetor_rebuild/model_b_carburetor.html
    I have dealt with a few of the B series carbs, they are good carbs (rebuilt an 53 bel air) that and I have seen them on several flattys with two or three of them in a row they were one of the best single bbl carbs at the time.
  14. Jamie Miles
    Alto, GA
    I've had a few
    Well, it's not much, but the Maverick had it's first kill today with the new carb. Mid 90's Chevy Suburban with big chrome wheels and stereo booming. He kept messing with me as we were driving down the road. Pulled up to a red light, when it went green we both stomped it. Smoked him off the line, then from about 40-55 we were both running even, he couldn't gain on me and I couldn't pull away any, then I pulled away from him on up to 80 and let off. Get to the next light and he asks what kind of car it is. Told him it's a ford Maverick, with a straight 6 in it. He goes "aww damn man, don't tell me that!" :rofl2:
  15. 73rustymav
    73rustymav Member
    thats great just dont tell them that you have c#$%y parts on there...:rofl2::rofl2::rofl2:
