can a 4 barrel conversion ruin our 302's???
Discussion in 'General Maverick/Comet' started by Flamesoldier, May 29, 2009.
  1. Flamesoldier
    Flamesoldier Member
    1973 Ford Maverick 302
    one of my neibors approached me who i have never met and asked what I was working on from the street I told him a maverick. He proceded in my garage to show him. He said oh mavericks i remember them. He worked at a performance shop in his past and reminised about hot rods. Anyway he was looking at my setup saw I had a 302 with a 4barrel and asked if i had matching heads? I said i took off 2barrel intake manifold and put on a 4bbl and basically coverted to a 4 barrel. He said wow thats not good you slowly killing your motor with 2v heads. he said that i need 4v heads to be running that setup how much of this is tru?????
  2. scooper77515
    None.
    Except that you ARE slowly killing your engine. But no more than you would by running ANY engine. Over time, it will wear out and die.
  3. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Nope, that's pretty absurd.
  4. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    That's the stupidest thing I ever heard ( well, at least one of them anyways ! ). :D
  5. Mavman72
    Your engine will be just fine the way it is.
  6. sierra grabber
    sierra grabber Certifiable
    northern nevada
    he probably was the parts delivery boy and doesn't understand A\F ratio or CFM. just smile and wave, then keep doin' your thing......
  7. scooper77515
    Hold on a sec. I now recall that if you mix and match 4bbl and 2bbl intakes and heads, it will offset the balance on the flux capacitor, and cause you to lose headlight fluid on the driver's side. So, YES, it could be dangerous...:outtahere:
    But, good thing you asked before assuming he was right.
    Now fill up the gas tank and go enjoy your newly found horsepower(y)
  8. Jamie Miles
    Alto, GA
    I've had a few
    It'll be fine, but you have to be sure to install 4 barrel muffler bearings at the same time. The 2 barrel muffler bearings will spin too fast with all that extra air, and they'll wear out really fast.
  9. Mavman72
    Why do I feel another radiator thread coming on??? :16suspect
  10. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    You'll hear all kinds of advice and storys,(Mavericks with factory 302 bosses, factory police packages, 11 second 1/4 mile from factory,) usally somebody knew somebody that went to school witha guy.... just take um with a grain of salt, i once had a guy tell me not to downshift because that was just 1 more upshift your tranny would never make before it wore out... da, why not skip 2nd very time and it would last 1/3 longer!
  11. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    In my case I have a 4.6l with 4v heads......I am running carb but it never came factory like that....OH **** it might explode my ass right out into outer space......:rolleyes: of course my 4v means 4 valves per cylinder in your case 4v means4 venturi as in a 4 barrel carb vs a 2v or 2 barrel carb.....
    keep up with the jargon..........
  12. scooper77515
    I always wondered why they used a "v" for "barrel". You learn something new everyday!
  13. rickyracer
    rickyracer Member
    Central Nevada
    66 Stang, 68 Cougar, 72 Comet GT
    4 barrel
    There was no 2 or 4 barrel heads for 302s. That was a 351C thing only. You hear it about 351Ws to. It was the pistons that are different. Even the 429 2 barrel engine had the same heads and comp, 10.5-1. The more carb with the 4 barrel made the more HP due to breathing.
  14. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That statement clears up why he is no longer at the performance shop!
  15. rayzorsharp
    Oh yeah, that's right...trying to get another thread off topic! Nobody said anything about radiators here. If you need info about radiators please use the search feature above. This thread is all about stupid neighbors, flux capacitors, and muffler bearings so lets please try to stay on topic!!! :bouncy:
