Timeslips Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2009-05-30, 10:03   #1
edwardsj
Member
edwardsj's Avatar
Vehicle(s): 1973 maverick
Images: 3
e85 engine
I'm kicking around the idea of building a new engine I'm thinking about a 331 or 347 with about 14.5 to 1 compression ratio. but i want to know the good and the bad about using e85 and high compression ratios. I have look on the web but found little. this engine will be e85 0nly.
__________________
JAMES
"Think knowledge is expensive......Try Ignorance"
edwardsj is offline   Reply With Quote
Sponsored Links
Old 2009-05-30, 20:57   #2
Bryant
forgot more than learned
Bryant's Avatar
Vehicle(s): 72 grabber
you get lower milage out of e85. you have to have a more expensive fuel system for it also. around here (san diego, ca.) e85 is extreemly hard to find and when you do its more expensive than regular gas. if these factors dont bother you then do it. it burns cleaner, the higher compression should make you more power than a standard pump gas motor could make you.
__________________
72 grabber, Its now satin black. The motor is a 302 dynoed at 321 hp. C4 trans, 9" rear end.
I work at San Diego Gear & Axle, so if you need any diff help or parts give me a call at (858)449-5656
Bryant is offline   Reply With Quote
Old 2009-05-30, 21:52   #3
CornedBeef4.6L
Voted off the Island
CornedBeef4.6L's Avatar
Images: 3
I iwll be running my 4.6l DOHC Carbed motor with e85. High compression here I come!!!!!
CornedBeef4.6L is offline   Reply With Quote
Old 2009-05-31, 19:29   #4
bmcdaniel
Senile Member
Vehicle(s): '70 Maverick Grabber
You have to flow more fuel, thus Bryant's mention of a special fuel system. And you want to run E85 in a car that you drive regularly, it doesn't stay stable very long and can eat rubber fuel system parts.
__________________
70 Maverick Grabber, 5.0 (Performer RPM 2.02/1.6 heads, RPM intake, Comp XE266HR roller cam, Holley 650 DP, Hooker 6901s), T5Z w/Steeda TriAx shifter, 9" "N" case Trac Loc w/3.89:1, 31 spline axles.
bmcdaniel is offline   Reply With Quote
Old 2009-05-31, 23:49   #5
PaulS
Member extrordiare
Vehicle(s): 1966 Mustang, 1972, 73, 73 and 73 Mavericks
Quote:
Great idea! 14:1 should be close to maximum running E85 though. If you plan on running carburetion you will need to locate an aftermarket maker that has the Ethanol conversion carbs - Holley has nothing to convert their carbs to ethanol. Holley does sell METHANOL carbs but not ethanol and they do have different metering needs.
My advice would be to adapt the fuel injection from a "flex fuel" car or go aftermarket for one.
__________________
Paul
1 each 72 2dr., 73 2dr., 73 4dr., 66 Mustang Coupe.
PaulS is offline   Reply With Quote
Old 2009-06-01, 01:24   #6
markso125
Member
markso125's Avatar
Vehicle(s): 1972 maverick 2 door LDO
Images: 5
This topic came up a little while ago and this is a good article to read on it
http://www.mustangandfords.com/techarticles/mufp_0708_car_gasoline_ethanol/carburetor.html
edelbrock does make a E85 carb from the factory the others are holley knock-offs
here is another arcticle on it
http://www.mustangmonthly.com/techar...ngs/index.html
__________________
Made in America...not just assembled here
markso125 is offline   Reply With Quote
Old 2009-06-01, 01:40   #7
PaulS
Member extrordiare
So.... when are we going to see E85 stations in Washington?
__________________
Paul
Old 2009-06-01, 05:24   #8
CornedBeef4.6L
Images: 3
The reason I am using E85 is I plan on running as much compression as I can get. It also runs cooler. When I am on that Vipers ass in a lil ole mav they can say that Bullmust of been corn fed
Old 2009-06-01, 13:56   #9
markso125
Member
markso125's Avatar
Images: 5
Quote:
We have one or two here in utah, and one or two biofuel stations too. At this point in time for me atleast it is more expensive to go 40 miles out of my way just to get some, also for us there is minimal price differentiation for the most part between E85 and E10 (regular gasoline) in part due to transportattion to get it here if it was more abundant I would definitely switch over.
__________________
Old 2009-06-01, 14:10   #10
PaulS
Member extrordiare
Yep, I saw one in Olympia when I drove by the other day but that is close to 60 miles away. When we have them closer and in more places I plan on changing all three Mavericks over to it and boosting the compression in the process. By using the optimum compression you can get better mileage (almost the same as gas) and at higher power levels. You have to use more fuel per pound of air but under proper conditions that fuel expands a lot more than the air it replaces. There are some problems that have not been discussed - like cold start preheating but I have solutions for that. I will be able to run it on a cold engine even on the coldest of days.
__________________
Paul
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
