1973 Yellow Dearborn Maverick
Discussion in 'Maverick/Comet Projects' started by spork1o1, Jun 6, 2009.
  1. spork1o1
    spork1o1 Member
    Michigan
    I started the tear down of my 1973 yellow Dearborn maverick.
    I got the interior out Friday. Passenger side front looks good from the inside, driver side needs toe board and part of the front floor pan.
    Rear pans need some work in front of the rear seat both sides, and under the rear seat both sides.
    No build sheet not under the seat, under the carpet, or behind the side panels. (front or back) and nothing above the headliner.:cry:
  2. PaulS
    THAT'S where I left my screw driver and ratchet! :tiphat:
    Looks like it is all in fair shape... Just some de-rusting, prep and paint inside.
  3. spork1o1
    spork1o1 Member
    Michigan
    more photos
    This weekend I will try to pull the front and back glass, and the dash. Then maybe start on the front clip and engine/trans.
  4. spork1o1
    spork1o1 Member
    Michigan
    The driver side toe board and driver side torque box are shot, and need to be replaced. The car has a bad cowl.
  5. blugene
    I tend to do the hard stuff first. That's why I am not finished tho, so don't listen to me :(
  6. mean_maverick
    wow.... looks like u have your work cut out for you. i wish you the best with it :)
  7. mean_maverick
    see if this doesnt help....
    http://www.martiauto.com/eminger2.cfm
  8. spork1o1
    spork1o1 Member
    Michigan
    I did some cleaning on the floor pans. not as bad as i first thought.
  9. mean_maverick
    they're not all that bad. ive seen alot worse.... :)
  10. spork1o1
    spork1o1 Member
    Michigan
    Got a little help on fathers day Pulling the engine and trans.
  11. Fat Tony
    Fat Tony Member
    Upstate,SC
    Looks about like what I just got finished repairing. Pretty much the same places and about the same amount of rust, you have one section on the drivers side that I didn't have to do (on the rear seat platform).. It took me about a month to do everything in my spare time ( couple hours here and there)..... now onto the QP's for me :)
  12. spork1o1
    spork1o1 Member
    Michigan
    Finely got my floor pans.
    [​IMG] [​IMG] [​IMG]
  13. mean_maverick
    really interesting car. cant wait to see it driving again :)
  14. Mavaholic
    Looks like somebody chopped up a solid car. Might have been easier to fix that one with yours. :D
