Painting front bumper extension...
Discussion in 'Cosmetic' started by A_Bartle, Sep 2, 2009.
  1. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    Org. Thread: http://mmb.maverick.to/showthread.php?t=47744
    Based on MavMan72's awesome idea, I'm painting the front bumper extension body color (yellow) up to the contour line, then I'm painting the area beneath the grill black. I prepped the area nicely, removing any wax and lightly sanded the surface. Last night I painted the black, and next I'll paint the yellow.
    However, since this is a vinyl product, here is where I'm nervous: I'm almost afraid that the black paint will pull up when I remove the masking tape along the contour edge (which I can't avoid). I'm going to let the black paint dry for several days, but is there anything else I can do to alleviate this potential problem?
    Originally Posted by Mavman72 [​IMG]
    Paint the area under the grill black to match the grill.Run the black out to the contour line.Paint the rest Yellow.Two toning the gravel guard will make it appear smaller by blending it in with the black grill.Cha ching $.02.Good luck.
  2. A_Bartle
    Michigan's Thumb
    Progress pics..
    Here are some progress pics. While I've got everything apart, I'm coating the inner bumper support with Chassis Saver, then I'm going to paint the radiator support across the front black (when looking at the car from the front, I always hated seeing the yellow behind the grill). I have not painted the front part of the bumper extension yellow yet, still letting the black part cure and dry really well (before having to tape it off)....
  3. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    Cool pics of your progress. Know what you mean with the paint . . . sorry I can't help with the ole paint pull-off thing. Good luck and let us know what worked for ya.
  4. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Isn't automotive painters masking tape less sticky than even regular painters tape? Definitely don't use regular masking tape, it'll pull it off for sure.
  5. Rando76
    Rando76 Member
    Claremore, OK
    Wow, those parts look NEW! Post pics when you get the paint done.
  6. Mavman72
    I should think as long as you prepped the surface well.The paint will stick no problem.Either way pull the tape carefully and slowly.Good luck with it!!!
  7. A_Bartle
    Michigan's Thumb
    Progress pics..
    Rando76: Yes the parts (as well as the rest of the car) do look remarkable, but you've got to remember, this car came from Alabama and it only had 14,000 when I got it. It always amazes me when I"m working on it and bolts just "loosen" up, without any problems or even breaking for that matter, so "not" typical (I even removed the catalytic converter, I totally figured the bolts would break or I'd have to cut them off, but they just backed off without any problems!).
    Attached are a few progress pics. I ended using electrical tape so I could get the curves to flow properly. Painted the yellow part yesterday and everything came out good. I also painted the front cavity black as well, so tonight after work I'll start putting everything back together...
  8. Rando76
    Rando76 Member
    Claremore, OK
    Nice! I look forward to seeing it installed.
  9. Craig Selvey
    Hey Art......isn't this keeping you from working on the Stallion? :D
  10. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Very nice work Art, looking great.:thumbs2:
  11. Dave B
    It's going to look awesome!! The yellow would really show through the grill, awesome idea!
  12. A_Bartle
    Michigan's Thumb
    Final results...
    Just got the car back together last night and snapped a couple shots. The best part is the "non-yellow" bleed through in the grill area....
  13. Rando76
    Rando76 Member
    Claremore, OK
    :thumbs2: That came out even better that I thought. I really like it! You're giving me ideas.... :D
  14. bobtackett
    bobtackett Member
    chicago heights ill
    1971 mav 302 4bbl headers
    front bumper looks SWEEEET.did you have it rechromed or get that lucky
  15. Dave B
    Wow, something so simple, and it looks so awesome!!! Very Nice!
