Shelby taillight conversion
Discussion in 'General Maverick/Comet' started by car-nut, Oct 7, 2009.
  1. car-nut
    car-nut Glenn
    conn.
    I know maybe this should have gone in another section, but since it could have fit into a few different places I thought it should just go here. Hope no one minds.:D
    I have been doing a bit of research on converting over to the Shelby taillights. I see that most guys that have done it have molded on the fiberglass rear panel while also cutting up the stock tail panel.
    https://www.mustangsunlimited.com/i...=Tail+Light+Panels+&+Hardware&CatKey=EMUSTANG
    With this new steel panel now available I was wondering if this might actually be the better way to go? Any thoughts? Keep in mind that there is fabrication either way...
    Also I see here that you can buy the whole thing in kit form with everything needed, tail pan, lights, bezels, and wiring harness. Any thoughts on this as well?
    There doesn't seem to be an easy or cheap way to do this. Of course if there was it would no longer be a unique thing to do I guess.
  2. justin has a 74
    kentucky
    Price: $729.88
    only drawback but i like the idea
    questions we need to concider... is the mustang wider?? is the mustang trunk taller??
  3. car-nut
    car-nut Glenn
    conn.
    I agree the price is expensive, but when you add up all the individual prices I would think the guys that have done this are into it for around the same money? Am I wrong there?
    I would never expect the panel to be a perfect easy weld in, but if the few guys that are on here that have done it with the fiberglass piece I can't imagine it would be any more difficult with the steel piece. How much fabrication are these guys doing now to fit the glass part?
    And by using the steel part you no longer need the fiberglass piece over top any more.
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    Very nice that would be the way to go. I love to work with steel.
  5. car-nut
    car-nut Glenn
    conn.
    Thanks for chiming in, you were one of the people I was hoping to hear from! I was curious what your and a few other guys here thought about this.
  6. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    I like the idea of using metal over fiberglass for the light panel myself. Here's a picture of what's included in the kit.
    Just from all the parts that would need to be tracked down to do the conversion, I completely agree that it more than likely would cost just as much, if not more, to find them on your own, refurbish the housings, and replace the lens & gaskets over buying them in kit form.
    Just my thoughts on the subject,
    -Scott H.
  7. Jamie Miles
    When you're read to wire up the sequential signals, just get a kit from http://webelectricproducts.com/. I think Ray pointed me in their direction when I did the Caprice lights. The universal kit I used was only 69 bucks, is super easy to wire up, and works awesome!
  8. Dave B
    I'd buy that kit, it's nice to have everything new. My next project will have Shelby tail lights.
  9. car-nut
    car-nut Glenn
    conn.
    Thanks for everyone's comments. I thought it looked like a good idea and wanted to make sure I wasn't missing something.
  10. krelboyne
    krelboyne Remember
    Salem, Oregon
    I know something about those
    My current project is a 1968 Mustang California Special, it uses the same fiberglass rear panel as the 1968 Shelby.
    I measured my fiberglass repop rear panel and it is 60-1/8 inches wide.
    I don't actually have a Maverick or Comet yet, if this is going to be too wide? I think that the steel panel would be the way to go and section it down narrower if need be.
    Capt Bondo is right, Shelby and AO Smith sourced the tail light parts from a 1965 Thunderbird. Tough to find in good condition.
  11. 302-72-mav
    302-72-mav Member
    sactown CA
    why not just put the tail lights on the mav's rear panel and save a bunch of $$ i don't think you will notice much of a diff with that mustang panel any way :cool:
  12. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    The light bezels are taller than the raised part of the panel. To make them look right you have to cut out the raised area and replace it with flat sheetmetal. That is how I (and some others) did mine.
  13. 302-72-mav
    302-72-mav Member
    sactown CA
    i don't like it with the flat panel look i like it with the contour of the tail lights:thumbs2:
    mustang
    this is with the mav rear panel
    jerry dutton likes this.
  14. car-nut
    car-nut Glenn
    conn.
  15. Grabber5.0
    Kansas City, MO
    71 Grabber
    That was a test fit before I cut the raised panel out. They just didn't look right hanging over the edges even though it was only a very slight overhang. The 67 Shelby lights look right at home on the flat panel. If I ever change my mind, it won't be that difficult to mold on the fiberglass panel, unless they start making them in metal for 67's as well...
