Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > General Maverick/Comet
Notices
Reply
Thread Tools Display Modes
Old 2009-12-08, 11:32   #1
disco123
Member
Vehicle(s): 71 comet with v8 conversion, hat 2 gts new in 71 and 74
Images: 2
replacing break light switch
ive been trying to replace my break light switch on my 71 comet, it came off in 10 seconds, NOW i cant get the damn new one on, what a bear it is. is there a simple way to put it back on? the plastic bushing is a little worn but ok, i just cant seem to get back together with the steering column in the way- the cheapest part is always the hardest one to get back on lol so far an hour and scraped knuckles no luck
disco123 is offline   Reply With Quote
Sponsored Links
Old 2009-12-08, 15:24   #2
rthomas771
Senior Member
rthomas771's Avatar
Vehicle(s): '74 Maverick 250 5-Speed. '60 Falcon V8 Toploader 9"
Images: 14
It is easier for me to squat down outside the car instead of climbing inside the car. To install the switch, position the switch, pushrod, and bushing and washers on the brake pedal pin and press the hairpin retainer into place.
__________________
Jeff in Georgia
rthomas771 is offline   Reply With Quote
Old 2009-12-08, 22:25   #3
disco123
Member
Images: 2
the plastic sleeve bushing is getting tattered, hanging up the switch asembley, does ford stock these bushings as old as they are they are pretty common on alot of older fords fords
Old 2009-12-08, 22:44   #4
rthomas771
Senior Member
rthomas771's Avatar
Images: 14
You don't need the plastic bushing for the brake light switch to work. If your set on having one...try a Mustang Vendor
__________________
Jeff in Georgia
Old 2009-12-08, 22:47   #5
Jamie Miles
the road warrior
Jamie Miles's Avatar
Vehicle(s): 13 Mavericks
Images: 362
I lost that plastic bushing a long time ago. No problems..
__________________
facebook
1972 Maverick - daily driven 215,000+ miles since 2005. 433,000+ miles total on the car. Now with a 1980 200 I6/SROD 4 speed.. 2.79 rear gear, Rochester BC carb, single out header, MSD ignition, Taurus fan, 3G alternator. 31 mpg hwy. @ 70 mph / 25 city.
Jamie Miles is offline   Reply With Quote
Old 2009-12-08, 22:50   #6
mean_maverick
Senior Member
mean_maverick's Avatar
Vehicle(s): '73 4dr
Images: 15
same here. lost many of them with no problems
__________________
1973 Maverick 4dr, 302/auto
1971 Grabber Blue 2dr 5.0/T5 -SOLD-
2003 Ford Mustang Mach 1, Azura Blue, Built, Blown & Stroked 562hp/501tq
http://73grabber.webs.com/1973grabberregistry.htm
mean_maverick is offline   Reply With Quote
Old 2009-12-09, 00:50   #7
disco123
Member
Images: 2
Quote:
great ill give it a try and maybe shim it wish a bushing on the outside of the switch before i put in the cotter pin to make sure is stays put
i had a 71 gt brabber blue- dealer mod called comet gt qualifier, and another one a few years later,never had a brake light switch go bad, just holes in the body from the buffalo ny salt hahahaa
thanks again charlie
Old 2009-12-09, 00:51   #8
disco123
Member
Images: 2
Quote:
thanks for the reply
charlie
Old 2009-12-09, 01:14   #9
disco123
Member
Images: 2
also will too much slack in the break peddel keep the switch from working?
Old 2009-12-09, 05:44   #10
CaptainComet
Senior Member
CaptainComet's Avatar
Vehicle(s): 72 Comet
Images: 195
Since you haven't mentioned it, I'm guessing that you don't have clutch pedal also in the way .... that made me invent a few new bad words ... ... makes you lose your mind after a while ... you can't look at it and touch it at the same time ... one or the other ... stupid tight in there.
Never replaced the brake light switch in my automatic Comet, but my first one, that was a stick car, went through three switches in 5 years.... ... of course ... ... Probably would be easier if you take the clutch pedal out, but I was pretty young and never figured that one out back then.
__________________
Awaiting its third life .................... Just a Memory..........
A fool and his money are soon partying.
Jeff
CaptainComet is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
