TFI ignition
Discussion in 'Technical' started by Racer_X, Dec 9, 2009.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    i just rembered that i have some TFI ignition parts, can i run TFI system on a carberated 302.....by the way i already know about the overheating thing with the modual. i found an article on line the shows how to month the modual on a heat sink away from the distributor http://www.therangerstation.com/tech_library/remote_tfi.htm.
    here are some pics of what ive got let me know if anything is missing...i know the modual and cap are missing....lol
  2. mean_maverick
    ive thought about it as well but he info is vague at best. i have a few extra remote mount units that i planned on using but decided not to bother with it
  3. Racer_X
    North Carolina
    I figured I'd go with this idea being that i already have the distributor...one less thing i have to buy for the motor
  4. mean_maverick
    i know the feeling. i have about 4 or 5 of them myself, and at least 2 of the remote mounted peices
  5. Bryant
    the tfi distributor doesnt have any mechancial or vacuum advance in it. all that was controled by the fuel injection computer. you can use the tfi dizzy with some sort of programable ignition like an msd, but it just would not be cost effective.
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    All you need to do is put the adaptor, cap and rotor on your duraspark distributor, then just change the wires to match the TFI coil in place of your round coil. Simple as that, this works for both the V8 durasparks and the I6 durasparks.
    The jeep guys have been doing this for years because AMC used the duraspark distributor setup untill 1986 in the CJ's when chrystler started buying them out. Here is a writeup to do it to a 4.2L jeep motor using a Ford 300 TFI setup and part numbers to match.
    http://www.jeepz.com/forum/engine/16904-tfi-ignition-upgrade.html
    for all the stock parts for the distributor you want this stuff , the distributor stuff is for a 84 mustang the coil and wires are for an 88 mustang
    here is the distributor adaptor
    http://www.autozone.com/autozone/ca...Cover&fromWhere=&searchText=&_requestid=11703
    here is the cap and rotor
    http://www.autozone.com/autozone/ca...otor+Kit&store=872&searchText=&brandName=Gold
    Here is the distributor (with steel gear you can also get it in a cast gear)
    http://www.autozone.com/autozone/ca...store=872&searchText=&brandName=Cardone+Reman
    here is the coil
    http://www.autozone.com/autozone/ca...tion&store=872&searchText=&brandName=Duralast
    and here are the plug wires to use
    http://www.autozone.com/autozone/ca...Wireset&store=872&searchText=&brandName=Bosch
  7. Racer_X
    North Carolina
    i have a blaster 2 coil from my six I'm going to use so that wont be necessary......unless the MSD TFI coils work better than my blaster2 coil(canister type)
  8. Racer_X
    North Carolina
    i have to buy another DS2 anyway unless the one from my six will fit which i highly doubt it would.
  9. markso125
    markso125 Member
    Lewiston Ut
    The TFI coil is comparable to the MSD blaster coil you have, usually this is just a cheap upgrade for people that have a duraspark II setup.
    The bigger cap reduces the risk of arcing from one terminal to another when utilizing the high voltage systems and the TFI coil puts out similar power to your blaster coil.
    So for someone with a duraspark II they could get similar power to your MSD ignition with maybe $20 bucks in junkyard parts. And if they wanted to upgrade to the MSD equivalent like the wires or ignition module it is an easy and fairly cheap improvement.
  10. Racer_X
    North Carolina
    i will keep than in mind in case i have to used the TFI coil that i have as a back up:idea:
