Putting motor back together
Discussion in 'General Maverick/Comet' started by Jeff S, Dec 15, 2009.
  1. Jeff S
    Jeff S Member
    NoVA
    none
    Yep, got it half-way torn down and realized I dont have time to do everything to it I want to do, so Im in the process of putting it all back together...we're supposed to be buying a house sometime in Feb/March(didnt know this when I started tearing it down), and we're not going to have a garage right off the bat at the new house so I cant have anything in pieces.
    So, the question is, can anyone supply me with a vacuum/wiring/hose diagram for the engine compartment of a '77 250? I could get a haynes manual but with christmas coming up and hours being cut back I can barely afford to eat :rofl2:
    I wrote down some things and other things I figured Id remember....but stupid me keeps forgetting I have random moments of sporatic memory loss...lol
  2. don graham
  3. Jeff S
    Jeff S Member
    NoVA
    none
    Thank you :D
    I should have used search, but it didnt cross my mind :(
  4. blugene
    Go to bed earlier :biglaugh:
  5. Jeff S
    Jeff S Member
    NoVA
    none
    I ended up out there from 10pm to 7am tryin to get that thing together
    If that vacuum diagram is right, Im missing every line except for 2...hopefully itll run better afterwards :biglaugh:
    Hopefully Ill fire it up tonight :yahoo:
  6. Jeff S
    Jeff S Member
    NoVA
    none
    Those diagrams has parts that I dont and they mingle with parts that I do have....cant understand what some of the parts are.
    These are all the vacuum ports that I have that I know of
    Removed frying pan, see pictures on next page
  7. Jeff S
    Jeff S Member
    NoVA
    none
    Anyone? This is all I need to get the car running :cry: I wanted to get it started tonight
    That thing thats supposed to be on the valve cover isnt there, just a bracket...do I need it?
  8. blugene
    Pics would be better. Looks like you have an electric frying pan lol. j/k...
    I would think that if all the vacuum ports were pluged it should at least start. I'm not sure what your talking about on the valve cover that's why I say pics might help. I think I have some diagrams but it would be a day or two... Someone may have changed things. I bought my 75 and it has a different motor even tho it's a 250 like it had. I tried to figure out what I needed and not needed and pluged off things. Seems to work and will sell the car eventualy so it's good. :rolleyes:
  9. Jeff S
    Jeff S Member
    NoVA
    none
    I would have taken pics but I have no way of uploading them from my camera to here(card reader is messed up) :cry:
  10. blugene
    You got one of them analog phones or something? :hmmm:
    :rolleyes:
  11. Jeff S
    Jeff S Member
    NoVA
    none
    I have a newer phone but cant email pics and I dont have the cable to upload them directly, I use a mini SD card
    I forgot about my wifes camera...so here are the pictures....the vacuum lines that are hooked up dont pay any attention to, as I started going by that other diagram...that may or may not be wrong
    Few more pics on the next post
  12. Jeff S
    Jeff S Member
    NoVA
    none
    Heres the other 3...the last pic is that bracket thats missing whatever it is that the other diagram shown that was supposed to be on it
    Thanks for any help :D
  13. Bryant
    from what i see there you should be able to get a way with a simple vacuum system. on the first picture, that port is what i belive is ported vacuum. there should be no vacuum at that port with the throttle closed but when you open the throttle it should see manifold vacuum. i would run a vac. line from that port streight to the vacuum advance on the distrubotor in pic #3. i would just plug off all the rest for now except for the one showed in the second pic on the second set of pics. that if for the vacuum modulator on the trans. that line should goto a manifold vacuum port.
    thats all that you should need to make it run.
  14. Jeff S
    Jeff S Member
    NoVA
    none
    Thanks! I'll try that :Handshake
    I have to work today and tomorrow so no chance of it getting done before friday :(
  15. Jeff S
    Jeff S Member
    NoVA
    none
    I got it running, but its not running good at all...take a look at this video and see what you guys can figure out.
    Air Cleaner is off
    Exhaust is off(header still on)
    First time it stalled I hit the gas, second time it stalled happened when idling
    Sorry about the lighting...its not well lit in there and I dont have a good place for the cam to get a engine view
    I just uploaded it, so it may take a few moments for it to be validated
