Truck help
Discussion in 'Other Automotive Tech & Talk' started by maverick75, Feb 22, 2010.
  1. maverick75
    2001 nissan frontier 2.4 Twin cam 2WD auto.
    when its cold it runs fine and everything no problem, but after a warm up of about 20 minutes the thing dies....you floor it and it will only go 10mph.
    it had 3 codes
    P0100 mass air flow circuit
    P0100 pd (same as above)
    P0420 catalytic.
    took out the MAF sensor and cleaned it but no luck, i even tried finding a replacement but i couldn't find a cheap one..
    how to you test a MAF sensor to see if its working?
    also somethings wrong with the charging system it only read 12 volts when i test it. And after testing it 3 times the engine died. But the lights don't dim or anything, and it has no problem staring up or powering the accessories :huh:
    any ides on whats wrong?
    thanks
  2. 302-72-mav
    302-72-mav Member
    sactown CA
    it gave a catalytic code does the exhaust stink or sound muffled // put your hand by the tail pipe and have someone rev it up to see if it is flowing good
    -------------------- sounds like a clogged catalyic converter ----------------------------
    if this is the problem
    either cut the pipe at the end of the cat then use a steel bar or something and brake all of the old cat up then rev the motor up to get it all out then weld it up
    or just have the cat replaced
    and i think a cloged cat can make your car run hot too ?????????
  3. JHodges
    JHodges thumper
    Dora Alabama
    If the cat is clooged it will glow when it gets hot. I would gut the cat first to see if it helps
  4. maverick75
    Exhaust flows fine.....
    Temp is fine, it just starts having problems when its warmed up. But it doesn't overheat.
    The cat code had came up on the last smog check, but the truck ran fine for the 3 months since its been.
    It will be replaced since we HAVE to have them here in California.
    But i don't think that's the problem.:hmmm:
  5. maverick75
    Put in a New MAF sensor two days ago and its running perfectly!(y)
    also the Cat code went away:huh: but it getting replaced anyways.
