What's your HP guess on this engine?
Discussion in 'General Maverick/Comet' started by mashori, Jul 13, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    we're gonna dyno the 331 engine once it's completed.
    Cam .542/.563 224/232 (112)
    185cc AFR heads
    1995 roller block
    probe pistons (-20cc)
    8.7:1 compression
    going to run a 600 holley
    intake will be performer RPM
  2. maverick75
    with big dyno headers and aggressive timing since its NA for now
    my guess is:
    459HP@6,500
    435TQ@4,500
  3. cheezno6
    cheezno6 Member
    Central ILLINOID
    What cam is that, a Lunati Voodoo?
    I'd say 395-410 @ 6200. You might do better with a 750 carb
  4. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    410hp @ 6100rpm was sticking in my mind as well, with a good tune. Probably 380 torque @ 4800rpm. Just a guess though.
    (You will post the numbers when it's done, right???)
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    trick flow stage 2.
    I would be really impressed if it made that much power with that low of a compression.
  6. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'll post for sure. The dyno guys needs a 2 day headsup. We're gonna rebuild the holley bryant has and I'm waiting on valve covers and an oil pan to come in. Maybe just some other little stuff left to finish but then it's off to the dyno . . . it's a little pricey though, $450 to dyno it. Gonna be picking up extra shifts at work.
  7. cheezno6
    cheezno6 Member
    Central ILLINOID
    Who's cam is it, looks like an off the shelf hyd flat tappet grind
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  9. cheezno6
    cheezno6 Member
    Central ILLINOID
    Mild for a roller. I'd say you'd be hard pressed to make more the 400 hp then
  10. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Just a thought (suggestion)... I would build it with around 9.7 :1 compression and use a 650 street avenger carb. It would make quite a bit more power and still be pump gas friendly.
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I should have mentioned guys,the engine is going to have a vortech supercharger put on it. So we built it with low compression. And I should add that I got a killer deal on a used supercharger. A V1 S-trim with all the hoses and brackets. I figure the headunit will need a rebuild and it's good to go.
  12. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    LOL nevermind, ninja edit I missed 331 part
    402hp at 5750
    Without a doubt on boost a block splitter
    Nice build :)
  13. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    on the low side 386hp high side 405hp
    Cam,Carb,low compression all workin against ya but the blower will wake it up for sure I see 535hp to 545hp w 6-9 pds boost or so......
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    We went over to some cam shop in San Diego, the guy said the cam we have is decent. He wasn't the most thorough guy I've run into but still, he said he would run that cam for both the NA and once the SC is installed. The carb seems too small for when I get the SC, we'll probably go with 650-700 blow-through.
  15. MikeG747
    MikeG747 Member
    Arkansas
    What blow thru carb will you be running once you add the charger?
