C-4 speedometer cable block off
Discussion in 'Technical' started by MikeG747, Jul 28, 2010.
  1. MikeG747
    MikeG747 Member
    Arkansas
    Do they make any sort of block off for the C-4 so the speedo cable can be eliminated?
    Thanks,
  2. PaulS
    I have made a few but I have never seen anything marketed for the purpose.
    A 7/8" cup type welch plug should fit snug. (don't use the disc type)
    Install it with a thin film of Loc-tite #518 to ensure that it will never leak.
  3. simple man
    simple man Member
    Bunnell,Florida
    I like your boat! In answer,Iv'e used an expandable freeze plug before. Easy to install,remove and it is unaffected by the heat and trans fluid!
  4. MikeG747
    MikeG747 Member
    Arkansas
    Thanks for the tips guys. I will let you know which one I go with. (y)
