Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2010-10-13, 22:12   #1
Jsarnold
Senior Member
Jsarnold's Avatar
Vehicle(s): '72 Sprint
Images: 13
Flamethrower Dist and Roller Cam?
The Pertronix catalog lists the FlameThrower distributor for sbf, EXCEPT 5.0. No listing for a 5.0.
When I asked about a steel gear for a roller cam, I got this response.
Quote:
Since the catalog printing we have confirmed the distributor fits the 5.0 liter engine. We also had the distributor gear tested with the factory roller cam on a spin tron machine at a cam manufactures plant. We found our gear works fine with Ford factory roller cam. However if it makes you feel safer then you can change the gear to a ford gear OEM gear as the distributor shaft is the same size at the gear.
I guess I believe them. Anyone using one of those distributors with a roller tappet cam?
Jsarnold is offline   Reply With Quote
Sponsored Links
Old 2010-10-13, 22:59   #2
maverick75
Gotta Love Mavs!
maverick75's Avatar
Vehicle(s): The mav is gone but i'm still here!
Images: 41
as long as its a steel/bronze/composite i dont see any problems with running it in a roller motor. But of course cast iron is a no no.
maverick75 is offline   Reply With Quote
Old 2010-10-15, 20:18   #3
PaulS
Member extrordiare
Vehicle(s): 1966 Mustang, 1972, 73, 73 and 73 Mavericks
Actually a cast iron gear would be fine - BUT the sintered iron gears will shread against the steel cam. (sintered iron is powdered iron formed under pressure)
__________________
Paul
1 each 72 2dr., 73 2dr., 73 4dr., 66 Mustang Coupe.
PaulS is offline   Reply With Quote
Old 2010-10-15, 20:29   #4
maverick75
Gotta Love Mavs!
maverick75's Avatar
Images: 41
I also thought they were cast.... It even states it in the description when you buy a distributor. So there sintered iron?
Old 2010-10-15, 20:33   #5
PaulS
Member extrordiare
Yep! they are sintered iron - just crack one and you can tell.
__________________
Paul
Old 2010-10-16, 11:13   #6
maverick75
Gotta Love Mavs!
maverick75's Avatar
Images: 41
Thank you for the info Paul.
Old 2010-11-25, 18:45   #7
Jsarnold
Senior Member
Jsarnold's Avatar
Images: 13
So Many Options ...
OK, so I was settled on a Duraspark/HEI hybrid as my second ignition for the Maverick. (I want an extra ignition in the trunk for road trips.) Lining up the parts, I find a rebuilt '85 GT 5-speed Duraspark for $50. HEI module is $22. Then, with more reading, I learn I should also get a better coil to get the advantage of the hotter ignition.
So, why not just buy a second HEI distributor and have the same wiring for the primary and backup ignitions. How about this one for $40? http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
Sure would make it simpler to swap out in case of a failure and I'm not bothered by the size of the HEI.
I asked the seller which gear it has. If its bronze or steel, I think I'll go for it.
Old 2010-11-25, 22:25   #8
Bryant
forgot more than learned
Bryant's Avatar
Vehicle(s): 72 grabber
those distrbtors use gm hei moduels. you shouldnt need to carry a complete distributor, just the moduel. unless your worried about the gear wearing out. it shouldnt if its the right one for the cam.
__________________
Building a 71 Comrick. all maverick in the front and comet in the back! kinda like a mullet.
im the head tech at San Diego Gear & Axle, feel free to ask for any differential help.
my 72 grabbers build and demise http://mmb.maverick.to/showthread.php?t=54351
my 71 comet build http://mmb.maverick.to/showthread.php?t=83544
check out my performance shop www.currentautoperformance.com
Bryant is offline   Reply With Quote
Old 2010-11-26, 08:28   #9
Jsarnold
Senior Member
Jsarnold's Avatar
Images: 13
Not worried about the gear but I like the idea of swapping out the entire ignition (module, coil, cap, rotor, ...) if I have a problem on the road. Then I can find the problem and fix it when I get home. I do appreciate your comments.
Old 2010-11-26, 12:01   #10
mojo
"Everett"- Senior Citizen
mojo's Avatar
Vehicle(s): 73 Comet GT-302 4bl
Images: 59
HEI Dizzy Upgrade
Quote:
I chked out that HEI setup. I like what I see. At that price u can afford 2 new units. I have the DuraSpark on my car but considering the change over. I wud like the setup where I get 12v to coil setup and eliminate the box under the hood. If you go this route I wud like to know what u think of this upgrade.
I have seen others here using similiar if not the same setup and kind of confused abt the dizzy gear issues. Im not clear on what gear I wud need in order not to do any damage internally. I suppose all the DuraSpark dizzy's have the same gear material. Maybe some of the folks here can provide me some feedback on this question?
__________________
Other hobbies: Amatuer (Ham) Radio and RC Aircraft..
mojo is online now   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
