Choosing a Speedometer Gear ...
Discussion in 'Technical' started by dmhines, Apr 18, 2004.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Got the formula ...
    Driven Gear = (Drive Gear Teeth * Axle Ratio * Tire Revolutions per mile) / 1000
    How can I tell how many drive gear teeth my Tranny has? It is a Toploader ... do Toploaders have a standard number of teeth?
  2. BlkWlf1968
    BlkWlf1968 Member
    Arlington,Tx
    1973 Maverick 2dr
    I think they all use a simular gear for the speedo. I know dealership has up to a 21 tooth in stock, but bigger is an aftermarket deal. The local speed shop here has them, but you might check Tranny shop for them as well.
  3. dmhines
    Cumming, GA
    Well I have been researching and found out they have either a 6 or 7 tooth gear. They are color coded so I guess I gotta take a peek in the hole and see if I can see it. I need either a 16 or 19 tooth gear depending on the color I find ...
  4. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Usually the 2.75 to 3.50 equiiped cars have a 7 tooth drive, and 3.50 to 4.11 cars have 6.
    Usually.
  5. courier11sec
    courier11sec Member
    Tucson, AZ
    color code.
    Which color is which tooth count?
  6. 74MAV
    74MAV Gearhead
    St. Louis MO
    74 Maverick
    I did not know that they could get them through the aftermarket but I put in the biggest one that Ford had available and I am still 4-5 mph off. I think the color mine is was purple or maybe blue been a few years since I changed it but the original was a white color
