Top Loader transplant
Discussion in 'Transmissions' started by Ken Thompson, Jun 26, 2011.
  1. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Next weekend I plan to remove the well worn C-4 out of my Maverick and replace it with a Top Loader 4 speed.
    Here is my parts list, (these parts I already have for a previous project that never went anywhere):
    Top Loader trans, Lakewood Bellhousing, Hurst Competition/Plus shifter and linkage.
    To buy Mustang Steve cable conversion kit, 300 Flywheel, 302 clutch assy, and all necessary hardware, shifter boot.
    Please fill in where I have missed anything.
    Thanks,
    Ken
  2. tody
    tody Member
    cologne, germany
    typo regarding the 300 flywheel, right?
  3. mercgt73
    And your toploader has the long input shaft for small blocks, correct?
  4. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Toby, the 300 flywheel is correct, it is a zero balance flywheel.
    Mercgt73, what is the length of a input shaft I need? I know there is a longer pilot bearing suggested.
    Thanks for your help.
    Ken
  5. mercgt73
    Are you swapping into a 302 V8? Or a 300 I6? I think we both assumed a 302 V8...
  6. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    I'm sorry I wasn't clear. I am keeping my 250 I-6.
  7. mercgt73
    Gotcha! If the tag on your toploader says it came from a smallblock (200 up to 390?), then you should be good, unless someone changed the input shaft. I am not sure of the exact lengths of the small vs. big block input shafts. Here is a quick blurb I found about it: http://www.fordmuscleforums.com/all-ford-techboard/412018-toploader-input-shaft.html
    They do talk about the extended pilot, which is an option. But from what I have read (no experience here, just here say), that the "right way" is to replace the input with the correct longer input.
    I could be way wrong here, but I ran into this with my 390 tagged toploader and my 302. My input shaft was too short. Which I found out AFTER I drove the car for years.
  8. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Thanks Rusty,
    I just looked up the transmission on David Kee's site. My trans is a RUG-E which is a 1967 289 transmission wide ratio. The input shaft length, that goes into the pilot bearing, is 1.135 long.
    After looking at NAPA's web site,I think I am going with a 1985 F-150 flywheel, 11" clutch, 88 Mustang Release fork. The Lakewood Bellhousing specifies changing the pilot bearing to Ford's C5TZ-7600-A. Tomorrow I'll be hitting the Ford dealer for that.
    Ken
  9. mercgt73
    Ok, cool! Hopefully I did not introduce unnecessary doubt, just wanted to make sure you did not run into the same problem I did. Good luck with it! (y)
  10. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Thank you for all your help. The thickness of a 300 flywheel became a concern, I decided to buy a FMS 302 0 balance flywheel, ZOOM 10 1/2" mustang clutch assy and all the arp fasteners.
    I really want this project to be finished on Monday the 4th.
    I can't wait to start shifting again.
    Again Thanks,
    Ken
  11. John B
    John B Member
    Ontario, Canada
    '73 Mav
    I'm putting a toploader into my Mav too. I wonder if you can tell me what Hurst shifter you are using (parts numbers for the shifter and the installation kit would be greatly appreciated. Thanks. John B
  12. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Hi John,
    I am using Hurst Competition/Plus Shifter P/N 391 3180 and Installation kit 373 5587. If you send me your email address, I'll send you a copy of the email's I got from a Maverick/Comet member that includes his input on putting a TopLoader in his Mav.
    Thanks,
    Ken
  13. paxtond
    paxtond Member
    Ontario
    1971, 1976 Comets
    I may be off base here but are you using a Lakewood Scattershield designed for a cable clutch set-up?
  14. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
  15. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Here is a list of all the parts I used for my Automatic to Toploader swap. Since you are not using factory linkage you can remove those parts from the list:
    Here is the complete list of parts for a swap to make it just like factory ...
    Here is a list:
    Clutch Pedal
    Clutch Pedal Pad
    Brake Pedal
    Brake Pedal Pad
    Pedal Bushings
    Clutch assist spring & bracket
    Rod from pedal to equalizer bar
    Clutch rod boot at firewall
    Clutch equalizer bar (Z bar)
    Frame side Z bar bracket
    Engine side Z bar bracket
    Bracket bushings, C clips and felts
    Rod from Z bar to clutch fork
    Z bar springs
    Bell housing
    Engine block plate
    Pilot bushing
    Flywheel
    Clutch disc
    Pressure plate
    throw-out bearing
    Clutch fork
    Clutch fork pivot
    Bell housing boot)
    Transmission
    Shifter
    Upper shift boot and bezel
    Speedometer Cable and Gear
    Transmission Cross Member
    Transmission Insulator
