Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2011-06-29, 14:38   #1
Fastkarz
Member
Fastkarz's Avatar
Vehicle(s): 1972 Maverick Grabber 302/C4
Images: 7
Headers cause Bumpsteer - Help !
Ok so I installed hedman headers and the drop bracket for the power steering ram. Headers are great, steering works ok....BUT when I hit a bump I change lanes. The power ram is no longer parallel to the center link so it is most likely the cause of the bumpsteer.
I know I am not the only guy who has done this swap. Other then holding the steering wheel tight what have others done to fix this ??
-Removing power steering or headers is not an acceptable answer
Thanks
Sean
Fastkarz is offline   Reply With Quote
Sponsored Links
Old 2011-06-29, 15:46   #2
mercgt73
Senior Member
mercgt73's Avatar
Vehicle(s): 1973 Comet GT, 1974 Mustang II
Images: 6
Quote:
Make sure that your drop bracket is not flexing. Have someone move the steering wheel back and forth while you lay on the ground and watch the bracket. If it moves back and forth, that might be the cause of your bump steer.
__________________
-- Rusty
mercgt73 is offline   Reply With Quote
Old 2011-06-29, 16:03   #3
Bob Wiken
Chronologically Gifted
Bob Wiken's Avatar
Vehicle(s): 1973 maverick, '87 306 H.O., roller rockers C4
Images: 5
I had a problem with the bushings at the lowering bracket wearing out very quickly. check to see if they are still intact
__________________
He who dies with the most toys, is, nonetheless, still dead.
Bob Wiken is offline   Reply With Quote
Old 2011-06-29, 16:12   #4
Dave B
MCCI Ontario Rep.
Dave B's Avatar
Vehicle(s): 3 Grabbers
Images: 42
Yea, make sure the bracket is tight. I had one pull out of the frame mounts once..it was kinda scary and fun all at the same time....
__________________
Dave B is offline   Reply With Quote
Old 2011-06-30, 01:08   #5
PaulS
Member extrordiare
Vehicle(s): 1966 Mustang, 1972, 73, 73 and 73 Mavericks
If you can hold the steering wheel and it prevents the side travel it is NOT bump steer. what you describe is an alignment problem or worn parts.
__________________
Paul
1 each 72 2dr., 73 2dr., 73 4dr., 66 Mustang Coupe.
PaulS is offline   Reply With Quote
Old 2011-06-30, 07:06   #6
injectedmav
Member
injectedmav's Avatar
Vehicle(s): 1972 Maverick 2dr 5.0l EFI, 2003 Expedition(wife's), 1991 Toyota p/u
Images: 28
BUMPSTEER is a change in alignment angles(usually toe) when the suspension compresses or rebounds. The ram being aligned only affects the assist, not geometry of the suspension. I would check the ball stud for looseness in the valve and the bushings at the drop bracket like the others mentioned. Frank posted the procedure on another thread for adjusting the ball socket in the valve and greasing it will help also. Wider tires will make it much worse as well. Any other changes than the headers? Sounds like there is a little more going on than the ram relocation.
__________________
"Do or do not, there is no try."
Yoda
injectedmav is offline   Reply With Quote
Old 2011-06-30, 09:51   #7
Fastkarz
Member
Fastkarz's Avatar
Images: 7
Lots of changes were done at the same time. disc brake conversion from a 75 Maverick, Addco front sway bar, headers, drop bracket, etc.
Since the brakes came from a P/S V8 Maverick so I can rule that out. Tie rods were for a 75 and I saw no difference in the linkage when I had the cars side by side.
Front end parts are tight, I did the alignment myself and went 1/2 degree more on the camber. Strut rod bushings, ball joints, front springs and shocks are new.
I hear you about the frame nuts pulling out. I had the same problem and welded a piece of 1/4" plate to the frame. Overall height of the drop bracket did not change since I already had a 1/4" spacer above the bracket to get it to clear the headers.
The p/steering control valve was rebuilt last year, no play in the ball socket. The P/Steering ram is unknown age but the socket to the center link is tight and I have new rubber bushings where it connects to the drop bracket.
Thanks for all the suggestions guys
Anybody recommend a different header that clears the P/Steering?
Old 2011-06-30, 14:44   #8
PaulS
Member extrordiare
Why more camber - the usual settings for good handling use less camber.
It sounds like you should have the alignment checked by a professional.
__________________
Paul
Old 2011-06-30, 14:47   #9
injectedmav
Member
Images: 28
all of them I know of require the ps ram to be dropped with the exception of shorties. What did you end up with on camber(+/-), what size tire are you using, and did you lower the car at all?
__________________
Yoda
Old 2011-06-30, 21:09   #10
Zooomzoomguy
Member
Zooomzoomguy's Avatar
Vehicle(s): 73 maverick, 2 door
Images: 5
i like lots of neg camber, i run -1.3 degrees on the front on my daily driver
__________________
347 4340 forged stroker, h beam rods, forged alum pistons, lunati voodoo cam, 233/241 duration, .538/560 lift, stealth intake, holley 750 carb. Roush200 cylinder heads, hooker 6901 headers with dual 2.5inch 40 series flows and h pipe, C4 tranny with 3k stall convertor
Zooomzoomguy is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Tags
bracket, bump, bumpsteer, drop, steer
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
