Maverick Taxi Cab Package
Discussion in 'General Maverick/Comet' started by Craig Selvey, Aug 16, 2011.
  1. Craig Selvey
    I have the 1977 Ford Taxi Cab brochure. This would include the Ford LTD, LTD II, and the Maverick. Here is what it lists for a Ford Maverick.
    Maverick Taxicab Package
    The Maverick Taxicab Package is available on the 4-door sedan model and includes the following items as standard equipment:
    - Automatic Transmission with First Gear Lock-Out
    - Auxiliary Transmission Oil Cooler (Externally Mounted)
    - Five-Strand Roof Light Wiring (Holes in Roof on Request)
    - Heavy-Duty 60-Ampere-Hour Battery (Includes Heat Shield)
    - Heavy-Duty Alternator - 60 Ampere
    - Heavy-Duty Suspension
    - Power Steeting with Oil Cooler
    - Coolant Recovery System
    - Two-inch Rear Brakes with Flared-Drums
    - Extra Cooling Package
    - Transistorized Voltage Regulator
    - Accessory Feed Connection
    - Rear Door Courtesy Lamp Switches
    - Deluxe Sound Package
    - Heavy-Duty Front Seat
    - Heavy-Duty Rear Seat
    - Assist Straps on RH and LH Center Pillar
    - Black Carpeting
    - C78 x 14 Bias Ply Tires
    - 14 x 6-inch Wheels
    It also lists the motor as a 250-6 cyl. Rear axle ratio of 2.79:1
  2. Dave B
    Wow, that's pretty cool!!! I could just imagine one in yellow, with steel wheels with little hub caps....
  3. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    thanks!!! great info!
  4. jmgford
    jmgford Member
    Iowa
    Here's one:
  5. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    :hmmm:
    What's that about?
  6. JPL
    JPL Member
    Ohio
    1975 Ford Maverick "Police Edition"
    Very interesting....but at first I thought why would the "Taxi" cab extras be the same as the "Police Package", but after reading what they came with I can see some useful edtions. Wonder if those items listed can be found?
  7. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    im still wondering why police cars are delivered with IL6?
  8. Dave B
    Pretty rare, since it doesn't exist anymore, burnt to the ground.
  9. jmgford
    jmgford Member
    Iowa
    My guess would be a preventive measure to keep aggressive taxi drivers from throwing the trans into 1st to slow down, and breaking transmissions.
  10. jmgford
    jmgford Member
    Iowa
    Probably figured if horsepower for pusuit was desired, they would order a full-size with a big block.
  11. Craig Selvey
    Some of these items I have never heard of or never seen (Rear door courtesy lamp switches, assist straps on RH and LH center pillar, etc). Who knows if any were ever ordered.
  12. maverick75
    what does the " Coolant Recovery System" look like?
    I'm imagining It's an overflow bottle.
  13. Craig Selvey
    I would say that is correct.
  14. JPL
    JPL Member
    Ohio
    Well, allow me to take a stab at this:
    I believe the "Coolant Recovery System" recovers any coolant that may be in need of recovery. Coolant that is in no need of recovery does not and will not be recovered.
  15. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
    Fancy name for a old window washer jug :rofl2:
