Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Miscellaneous Forums > Other Automotive Tech & Talk
Notices
Reply
Thread Tools Display Modes
Old 2011-09-04, 17:22   #1
ford84stepside
Lone Wolf
ford84stepside's Avatar
Vehicle(s): 1947 Lincoln Zephyr Coupe
Images: 26
Suspension question for the experts
I have a question maybe somebody can tell me if my thinking is right. I have a suspension sorta like a Maverick or Mustang II, upper and lower control arms, with strut rods off the front of the lower control arms to brackets bolted to the frame. It is a torsion bar setup now, I will be doing away with the bars and using coil overs from the bottom control arm to the top shock bracket, reinforcing the bracket as necessary. I believe the strut rods will be required to keep the LCA from moving on braking . Question is, can I reverse the strut rods, mounting them behind the front end like a Mustang II, instead of in front like a Maverick? I think that they would work the same way, just the force excerpted on them would be the opposite to the way they are now, push when they pull now, pull when they push now. They have rubber bushings on both sides of the bracket. This would be done to clean up the lines of the front end when looking from the front. It is an exposed suspension [no fenders], and I don't think the brackets sticking down under the frame beside the grill shell would look so good. The strut rods bolt onto the LCA with two bolts, and look to be reversible. I will mod the front brackets as needed to bolt to the back side of the frame, behind the tire. Does this sound feasible? Or am I stuck having to put the ugly things up front?
ford84stepside is offline   Reply With Quote
Sponsored Links
Old 2011-09-04, 18:32   #2
Bryant
forgot more than learned
Bryant's Avatar
Vehicle(s): 72 grabber
yes you can move it to the rear. you just have to get the location right
__________________
Building a 71 Comrick. all maverick in the front and comet in the back! kinda like a mullet.
im the head tech at San Diego Gear & Axle, feel free to ask for any differential help.
my 72 grabbers build and demise http://mmb.maverick.to/showthread.php?t=54351
my 71 comet build http://mmb.maverick.to/showthread.php?t=83544
check out my performance shop www.currentautoperformance.com
Bryant is online now   Reply With Quote
Old 2011-09-04, 18:43   #3
rthomas771
Senior Member
rthomas771's Avatar
Vehicle(s): '74 Maverick 250 5-Speed. '60 Falcon V8 Toploader 9"
Images: 14
Here's a suspension answer...but not from an expert.
Jimmy’s racecar front suspension was replaced with a Torsion Bar Suspension from a '71 Plymouth Duster with a Pinto rack & pinion steering. Mopar's have rear mounted strut rod looking things mounted around where the transmission mount is located
__________________
Jeff in Georgia
rthomas771 is offline   Reply With Quote
Old 2011-09-04, 18:57   #4
ford84stepside
Lone Wolf
Images: 26
Quote:
That's what I wanted to hear! Since the frame is the same width, location should be easy.
Forgot to say what this is on, the Toyota PU frame on my street rod.
Old 2011-09-04, 19:03   #5
ford84stepside
Lone Wolf
Images: 26
Anybody that knows more than I do can be an expert, Jeff!
Just trying to get some good info from someone who knows suspensions better than I do.
Old 2011-09-04, 20:46   #6
65 comet
Member
65 comet's Avatar
Vehicle(s): 65 Comet Caliente Hrdtp, 65 2+2 Mustang Fastback 4 spd 53 F100 project 67 Ford 1 ton 4x4 project
When I saw your question I scratched this out for you as an Idea you might like, or maybe not. After you reverse the strut rods you can dress them up a little to help blend them in.
65 comet is offline   Reply With Quote
Old 2011-09-04, 21:07   #7
Mavman72
I'm mister heat mizer...
Mavman72's Avatar
Vehicle(s): 1972 Maverick 2 door.Original V-8 3 spd std shift.Also a 72 one owner Sprint sporting a 351 Windsor
Images: 29
Hair pins!!! Cool. that would look cool and be adjustable...
__________________
"Buying a Maverick is easy, restoring one is not"
Mavman72 is offline   Reply With Quote
Old 2011-09-04, 21:32   #8
ford84stepside
Lone Wolf
Images: 26
Yeah, I was thinking about that idea, too. Not sure how I'd connect them in the front and still make them look right. A single strut rod with heim ends, attached to the outside of the frame might work, too. Would look like a split wishbone. Trying to get as traditional a look on the front end as possible without going to a straight axle. Now that I know that I can reverse them, I have a lot of ideas. As the weather cools down, maybe I can get the front end together before it gets too cold to work outside....
Old 2011-09-04, 21:47   #9
65 comet
Member
65 comet's Avatar
With this idea you use the original strut rods and weld the upper and lower tubes on and put some plates inbetween if you should desire them. I added another pic since the pdf file wasn't very clear. Good luck.
Old 2011-09-05, 01:07   #10
mav1970
Bob Hatcher
mav1970's Avatar
Vehicle(s): 69.5 Maverick 393 Cleveland Stroker
Images: 201
Quote:
Now you know one should not deviate from stock there Mr. Sherman - you know I sure wouldn't
__________________
Every step of my project has been temporarily impossible
My Insane 1969.5 Street Project Thread
mav1970 is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
