gauge cluster
Discussion in 'Parts Interchange' started by bartikus, Sep 20, 2011.
  1. bartikus
    bartikus Member
    salt lake city, ut
    so the gauge cluster in my 77 is disintigrating and only a few of the functions actually work. i had a spare 70 cluster and was going to swap all the gauges on to it but the female conector hole is a different size. i belive i remember this being discussed on here before but i am having a hard time finding it. what year of cluster do i need to find? what changes did they make from year to year on the clusters?
  2. yellow75
    Tillamook Oregon
  3. maverick75
    I have a 71 cluster in my 75.
    It was pretty easy to figure out just having the two side by side.
    With that tech article it should be a breeze!
  4. Craig Selvey
    While not expensive....it will not be cheap. The last one I saw on ebay (last week) fetched near $40. Hard to find....and people need them.
    I would go with the parts swap as decribed in the other posts.
  5. bartikus
    bartikus Member
    salt lake city, ut
    thanks for the info i already have the one from the 70 i tore apart so i think i'l go that route. last night i used electrical tape and taped it back together for now i'm just not getting a good connection on at least half of the connectors on the printed circut.
  6. Craig Selvey
    I really don't think you will get the 1970 cluster to work for you. Totally different plug. You need to find the correct cluster that will fit your plug. See the links that were posted...they will help.
  7. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    Thats what I love about this site. I gain so much knowledge just reading post. I had no idea my 70 cluster was different then the rest of the years.
  8. bartikus
    bartikus Member
    salt lake city, ut
    i might still have a 74 cluster at my parents house in their shed i have been meaning to grab the spare parts i left there any ways so this is a good time to do it.
  9. rthomas771
    I used a 75 cluster in my 74...after I swapped the gauges so I can go 120 mph and run regular fuel instead of unleaded only.
    [​IMG][​IMG]
  10. maverick75
    Here's my before and after, 75 cluster to 71 cluster.
    I Love the silver inlay in the early gauges, plus more MPH is always nice :D
  11. bartikus
    bartikus Member
    salt lake city, ut
    does your mph match what speed you are actually going
  12. alaskamaverick
    alaskamaverick Member
    Spokane, WA
    If your real lucky you can pick one up off of ebay, I just picked one up last week for $20.50. in excellent condition. I have one from a 1974 if you cant find one.
  13. maverick75
    It's a little slow, but that's due more to the 27" tall tires I run.
    The stock speedometer never worked so I don't have that to compare it to.
  14. rthomas771
    I tried a 71 cluster on my 74 and one of the circuit tracks crossed over the plug receptacle hole. I didn't want to cut into the curcuit board to clear the hole for the harness plug. I ended up buying a cluster from a member for $25 or $30
  15. maverick75
    I don't even remember how I did mine, it was 5 years ago.
    But its in there and everything works fine so I'm not gonna mess with it :D
