torx fastener
Discussion in 'General Maverick/Comet' started by OLD GOOSE, Nov 28, 2011.
  1. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Does anyone know the size of the torx bit to remove seat belts on a 72 Maverick ?
  2. Acornridgeman
    Wisconsin
    Pretty sure it is a T-50
    As a side note. Those cheapo Chinese tork sockets shatter like glass on these bolts as they are often rusted. Buy a good one and use a breaker bar.
  3. Craig Selvey
    I would get one from Sears...a Craftsman. When it breaks...and it will....they will replace it for FREE.
  4. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Thanks was going to buy a t-50 today at sears but I wasn't sure.
  5. Craig Selvey
    I just went out to my garage to confirm: Yes....it is a T-50.
  6. Dave B
    Spray them with some penetrating oil first, and let them sit for a bit. The rear ones are the worst.
  7. Joe Dirt
    x2 where they go through the floor spray them from underneath and up top
  8. Acornridgeman
    Wisconsin
    PB BLASTER ......... :thumbs2:
  9. maverick75
    Mine came out like butter! Just a T handle one was needed.
    I had more issues just trying to remove the plastic plugs :D
  10. Dave B
    But...you live in California....:tiphat:
  11. Bob Wiken
    Fayetteville, Arkansas
    I had no problems with mine here inArkansas either, alothough mine do go in and out like the are going through a lock nut
  12. blugene
    Mine were tight enough to shatter the cheap torx I used on the first attempt. Once it broke free it wasn't hard coming out the rest of the way or going back in. Mine had/has no corrosion or rust. I'm sure they were set at a high torque due to the fact that "safety" was the concern. We all know that tighter is not always better or even necessary in some cases. I can't tell you how many "cheap dam" cross bars my dad twisted :rofl2:
  13. maverick75
    Yup we trade off rust for sun dried plastic :(
  14. injectedmav
    injectedmav Member
    Georgia
    A good 3/8" impact set on the lowest setting will usually break the threadlocking compound free without busting any knuckles.(y)
