Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Maverick/Comet Forums > Technical
Notices
Reply
Thread Tools Display Modes
Old 2011-12-11, 10:38   #1
scooper77515
Accepting Hand-me-downs
scooper77515's Avatar
Vehicle(s): 74 Mav 5.0 +.040 & C4
Images: 19
How long should RTV cure before refilling with oil?
This is applicable for the rear end, transmission pan (if not using a gasket), I guess even for installing an intake.
Currently, doing the 200,000 mile maintenance on my truck, and using RTV on rear differential and transmission pan.
On pan now, I have followed directions on RTV (1/4" bead, tighten finger tight til squeeze out the sides a bit, wait one hour, tighten another 1/4-1/2 turn).
So, now, how long before it is safe to refill the transmission?
RTV package says "dries in 1 hour, fully cured in 24 hours". So, is it safe after one hour?
Also, it is only 50-55 degrees in the garage, so what is the answer for a typical day, and how much more time should I wait in this cooler temperature?
__________________
5.0 +.040 , roller .537/.574 224/232, 1.72 roller rockers, GT40, Holley 750 Street HP on Torker 289, 3.80 w/spool, CalTracs, dual Super44 Flows, R&C MII power rack suspension (no shock towers!), Vintage-Venom rear disks, lots of noise and everchanging custom calico paint
If you don't like it, I don't care
scooper77515 is online now   Reply With Quote
Sponsored Links
Old 2011-12-11, 11:37   #2
Eastern Raider
Member
Eastern Raider's Avatar
Vehicle(s): 1970 maverick ford mustangs 1993 f150
Images: 12
Sounds safe after 1 hr. to me, with my mechanical back ground. Check into the latest thing ,Indian head gasket sealer by permatex. Transmission man once told me to not use glues on transmissions, and I dont. I hope this helps.
Eastern Raider is offline   Reply With Quote
Old 2011-12-11, 11:52   #3
CornedBeef4.6L
Voted off the Island
CornedBeef4.6L's Avatar
Images: 3
Next time pick up the "The Right stuff" rtv sealer from permatex you can use it and 5 min later fill up.
CornedBeef4.6L is offline   Reply With Quote
Old 2011-12-11, 12:00   #4
Dave B
MCCI Ontario Rep.
Dave B's Avatar
Vehicle(s): 3 Grabbers
Images: 34
Quote:
X2, I use the black stuff.
__________________
Dave B is offline   Reply With Quote
Old 2011-12-11, 12:04   #5
CornedBeef4.6L
Images: 3
Quote:
a fun fact permatex created the right stuff for the oem assembly lines....they needed a fast cure product so the line would move along with no slow up!!!!!
Old 2011-12-11, 12:57   #6
darren
Senior Member
darren's Avatar
Vehicle(s): 72 302 Maverick
Images: 12
Our RTV at Chrysler is formulated for trans pans and fluids.(permatex) NO wait time at all. Bolt the pan on and fill it up. Never had one leak. The fluid wont penetrate the bead created in the pan so it doesnt effect the seal between the pan and case. Used it for 20 years on valve covers and trans pans. Our differential rtv is a redish orange color designed for diff fluids. You need the right rtv for the right job. If in doubt go grab a tube from the dealer. The dealer wont use a product that takes long dry times nor would the factory supply us with such product.
__________________
Rebuilt HO short block.Forged pistons. Fly cut. X303 cam. 9.5:1 E7 heads. Mild port work. Motorsport 1.6 Roller rockers. Motorsport dual plane. 600 Holley. 750 bowls and metering blocks. C4. Extra clutches. Shift kit. Trans kool pan. 3500 custom 10 inch converter? 4:11 Detroit locker. A bit dated but still fun. http://www.youtube.com/watch?v=CaZZJ369rpA Project
darren is offline   Reply With Quote
Old 2011-12-11, 13:07   #7
scooper77515
Images: 19
The last time I took it to chrysler, they used black. And by the time I got there to pick it up, there was a huge puddle under the truck. They took it back in and had to do it again.
I took on the trans job this time, and now I remember why I took it to Chrysler the last 2 times.
I HATE!!!! transmission fluid. I got it EVERYWHERE!!!
__________________
Old 2011-12-11, 13:46   #8
darren
Senior Member
darren's Avatar
Images: 12
Thats not the RTV's fault Scoop thats the tech and preparation. ITs not rocket science. Make sure no old RTV exists is the biggie. No oil remains on the surfaces. Thats the hard part but the ATF RTV will still work if a bit of oil exists on the surface. Its good stuff. I use a scraper or razor blade on the case and my 3m cookie on the pan. I clean with brake clean and a cloth. Bead the pan. Make sure the case is dry and clean. Put the pan up quickly and secure with a couple of bolts. Put in the rest and snug it all up. Dont forget the filter/filters not that I have ever done that.LOL.
__________________
Old 2011-12-11, 15:04   #9
PaulS
Member extrordiare
Vehicle(s): 1966 Mustang, 1972, 73, 73 and 73 Mavericks
I hate to find RTV on a transmission pan. First because most RTVs turn to jelly when exposed to ATF (that jelly is a PITA to clean out of oil passages and valve bodies) and second is that it is over-applied more often than not.
I use a gasket and Loc-tite #518 (gasket maker/flange sealer) because it is impervious to all fluids and temps and it cures in about one minute when it is tightened down.
It won't cure until it is tightened down, so you can apply it to both sides of the gasket (.010" film) and it will fill small imperfections yet it comes off with the gasket - no scraping or cutting required.
__________________
Paul
1 each 72 2dr., 73 2dr., 73 4dr., 66 Mustang Coupe.
PaulS is offline   Reply With Quote
Old 2011-12-11, 15:10   #10
Joe Dirt
six poppin'
Joe Dirt's Avatar
Vehicle(s): 1973 4 door
Images: 89
X2 rtv is no good for atf
__________________
1973 Maverick- 4 door Gapp & Roush tijuana Taxi "clone"
1957 Chevy 2 door post Turbo lsx GASSER project
Please visit my website!
https://www.facebook.com/JoeDirtFabrication
Joe Dirt is offline   Reply With Quote
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
