Discussion in 'Maverick/Comet Projects' started by jhohlfeld, Dec 30, 2011.
  1. jhohlfeld
    jhohlfeld Member
    Lexington KY
    71 Maverick Grabber, Isaac's 76 Maverick
    Hi, I just bought my project car. It is a 1971 Maverick Grabber with a 200 engine and 3 speed manual transmission. I had it running a few times but my brother and I can't get it to run right. It is in need of a carb rebuild. I am thinking that I am going to keep the 200 but do a few mods to it. I have been reading up on this web sight http://www.classicinlines.com/LogMods.asp#2VC. I am just not sure what carb to use with it.
    Later, Joel
  2. jhohlfeld
    jhohlfeld Member
    Lexington KY
    I got a few parts that I ordered for my car. I got the power steering gear box, V8 trans mount, and the disc brake perportining valve.
  3. mercgt73
    mercgt73 Member
    Parts are good! :dance:
  4. jhohlfeld
    jhohlfeld Member
    Lexington KY
    here is a few pictures.
  5. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    Hello from Winchester! :Handshake
    Good luck on the project, looks like for the most part a fairly solid maverick
  6. jhohlfeld
    jhohlfeld Member
    Lexington KY
    Hello, and thanks from Lexington
  7. Eastern Raider
    Eastern Raider Member
    middle Ga. warner robins
    welcome Joel:tiphat: I recomend a 1904 model Holley carb.I also have a Ford 200 six cyl. The 1100 Autolite carb is good but the accelerator pump housing bends and leaks. I have tried the carter RBS it runs good but the rebuild kit, accelerator pump, rubber didnt work. :16suspect kit problem there man! The holley 1904 is awsome in acceleration and idle :dance:,but watch for bent fuel bowl ears,that makes the bowl gasket leak. Yes there is a glass bowl 1904 model. If you just got to run a carb, I can tell you more. Send me a private message.:chirp:
