1973 Front Bumper Mounting Options
Discussion in 'Technical' started by mercgt73, Jan 11, 2012.
  1. mercgt73
    mercgt73 Member
    Has anyone mounted a '73 style front bumper without using the massive bumper inner support and the compression style bumper mounts?
    I understand that the "Impact integrity of the system will be comprised!" without the inner support, but I was thinking of a skeleton tubing version that will support the bumper and the filler panel at the same time. I also want to tuck the front bumper, so a benefit is that I could mock it up with the distance I want. Any ideas or pictures?
    Thanks! :Handshake
  2. Bob Wiken
    Fayetteville, Arkansas
    I just tucked mine without removing the inner bracing. But then, I'm not really worried about the weight
  3. mercgt73
    mercgt73 Member
    Gotcha. I kinda don't have the inner bracing, so instead of buying one and the bumper mounts, just thought I would make a mount.
    Thanks for the feedback. I guess most everyone ditches the '73 style in favor of the small bumpers. Anyone else?
  4. Dave B
    I left them alone on my green car, the 73 I'm working on now will have small bumpers. Unless your building a race car, there's no real need to go to all the work. I have a set of real clean bumper shocks (or whatever they are called) they came off my Arkansas car.
  5. mercgt73
    mercgt73 Member
    True, true.
    I will probably wait until I can get these parts in person (shocks/mounts/whatever and brace). I imagine the inner brace would be quite the shipping fee.
  6. Dave B
    Yup, it's pretty heavy....if you found a good one, you could always swiss cheese it, to lighten it up. Have you checked with Dennis Martin? he might have what you need.
  7. Craig Selvey
    I have some 1973 inner braces.
  8. mercgt73
    mercgt73 Member
    Nope, have not reached out to him yet. Might do that.
    I figured you would, but shipping would be high. Maybe this Spring or Summer I will be visiting family in Ohio.
  9. Craig Selvey
    I also go to the Columbus Swap Meets if that helps.
