Rear valance?
Discussion in 'Technical' started by ccheeks14, Jan 17, 2012.
  1. ccheeks14
    ccheeks14 Member
    Portland, OR
    1976 Maverick
    I have a 76 that I just did a bumper conversion on and the holes for the rear valance don't line up, I'm just curious how everybody else attached theirs?
    Also, do you have to have a cutout for the exhaust or can it just sit above it?
  2. maverick75
    I just lined mine up so the body line would be flush, then taped it with masking tape to hold it in place white I marked it with a marker then attached it with self tapping screws.
    Then for the bottom nut I ordered the kit from a mustang supply chain, since there's is similar.
    I'm not running the stock exhaust so I cant help on that.
  3. mercgt73
    mercgt73 Member
    My dual exhaust ran under my rear valance.
  4. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    mine is welded and now part of the car.
  5. 71gold
    your rear valance? if so, how do you get to the ...tank strap bolts?
  6. smegnl
    smegnl Roger Saffle
    Wadsworth, Ohio
    1970 Grabber Clone
    1970...no staps. Tank goes in thru the trunk...(y)
