speedometer trouble shooting.
Discussion in 'Technical' started by Lunchboxjr, Feb 7, 2012.
  1. Lunchboxjr
    Lunchboxjr Member
    Bay Area, CA
    1971 Ford Maverick
    My speedometer isn't working. How would I go about trouble shooting it to figure out what is wrong?
    Any and all information is appreciated.
    -Frank
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Check the speedo gear going into the trans. If its good replace the cable.
  3. Wrighttime
    Wrighttime Member
    Midlothian, Va.
    74 Maverick street car 73 comet drag car 74 comet drag car
    Speedo-Cable cluster
    Ck to see if cable came loose from speed o meter cluster very common. When this happens most times you will a scratching noise behind dash. Hope this will be a help.
  4. silver70
    silver70 Eric
    Phoenix, AZ
    '70 Maverick
    +1. Had a chewed-up gear in two different vehicles in the past 5 years.
  5. Lunchboxjr
    Lunchboxjr Member
    Bay Area, CA
    1971 Ford Maverick
    Thanks guys! Going to do this tomorrow. Anyone know where I can get a diagram of what I'm looking for?
  6. maverick75
