Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Miscellaneous Forums > Other Automotive Tech & Talk
Notices
Reply
Thread Tools Display Modes
Old 2012-06-18, 12:07   #1
Ryan
Ford Addict
Ryan's Avatar
Vehicle(s): 73 Maverick, 70 F-100, 93 Mustang LX 5.0 5-spd, 2014 Kia Optima SX Turbo
Images: 71
How bad would the wrong balance flywheel vibrate?
I did a clutch and flywheel on my 93 mustang this last weekend. Got it all togethor and have a slight vibration that feels likes its from the engine. it increases with rpm and does it moving or standing still, and with clutch pedal in or out.
Im thinking the flywheel was the wrong balance, misboxed or made wrong. Quetion is how bad would it vibrate if it had the 28oz. flywheel in it? Would it be like "Oh My god this thing shakes and something is wrong" or "hmmm somthing dosnt feel right".
__________________
Ryan is offline   Reply With Quote
Sponsored Links
Old 2012-06-18, 13:16   #2
RobbieG.
Member
RobbieG.'s Avatar
Vehicle(s): 75 Maverick, 72 Maverick sprint, 67 Mustang bracket car, 02 F250 4X4
Images: 52
We had the wrong flexplate on my sons car. It's not to bad a vibration but it will kill the main bareings.
__________________
RobbieRacer
RobbieG. is offline   Reply With Quote
Old 2012-06-18, 14:15   #3
Jsarnold
Senior Member
Jsarnold's Avatar
Vehicle(s): '72 Sprint
Images: 13
I had a very noticeable vibration from a supposedly correct flexplate. It was a manufacturing problem where the imbalance wasn't quite right.
If you had the wrong flywheel imbalance, i.e., 28 vs 50, I think it would shake pretty violently when reved.
If you still have the flywheel you replaced, with correct imbalance, you can compare the new one to the old. If you need to do that, PM me with an email address and I can send pictures and instructions on how I did that.
Jsarnold is offline   Reply With Quote
Old 2012-06-19, 09:37   #4
Ryan
Ford Addict
Ryan's Avatar
Images: 71
I think its supposed to be the right weight but its off quite a bit. over 1000 rpms and under 3000 rpms its hardly noticeable. but at idle you can feel it vibrate, and at 3000 rpm the whole car shakes. The old flywheel is long gone in the trash. stupid mistake now looking back at it. But it probably wouldnt make a difference, just gotta replace it with another and hope the next one is made right. Since this is a manual trans flywheel its hard to tell if the weight is right. Its not like on a flexplate where you can just look at the size of the weight thats welded on.
__________________
Old 2012-06-19, 10:28   #5
Jsarnold
Senior Member
Jsarnold's Avatar
Images: 13
Yeah, if you only changed one thing, you know what's causing the shake. In my case, I had new crank, balancer, flexplate, and torque converter so I had to find the culprit. Hope the replacement fixes it. Rework for defective parts isn't fun. Seems like I've done a bunch of it.
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
