Mobile Tags Register Gallery
Go Back   Ford Maverick / Mercury Comet Forums > Miscellaneous Forums > Other Automotive Tech & Talk > Non-Ford Engines
Notices
Reply
Thread Tools Display Modes
Old 2012-06-23, 07:39   #1
scooper77515
Accepting Hand-me-downs
scooper77515's Avatar
Vehicle(s): 74 Mav 5.0 +.040 & C4
Images: 19
10 HP Briggs and Stratton, only runs on CHOKE. Whassup?
Every 6 months or so, I fire up my portable generator. This time, it started right up but won't run once I take it off choke. It will run on half choke, but if I back it off a little it starts to starve and will sputter out on me. Runs smoothly with choke on, with or without air filter (it is clean and new).
My brother-in-law's machine is doing the same thing this season
Any ideas, hints, or solutions?
The machine is pretty much brand new. I have had it three years, run it maybe 10 or 12 hours. Fuel has been mixed with Stabil, and I swap it out every two years if I don't use it.
Not getting enough fuel?
__________________
5.0 +.040 , roller .537/.574 224/232, 1.72 roller rockers, GT40, Holley 750 Street HP on Torker 289, 3.80 w/spool, CalTracs, dual Super44 Flows, R&C MII power rack suspension (no shock towers!), Vintage-Venom rear disks, lots of noise and everchanging custom calico paint
If you don't like it, I don't care
scooper77515 is offline   Reply With Quote
Sponsored Links
Old 2012-06-23, 07:53   #2
MaverickDan
I wanna go fast!!!
MaverickDan's Avatar
Vehicle(s): 73 Maverick 4dr
Images: 3
Sounds like the main jets are clogged. If it has a fuel shutoff next time you use it set it to off and let it run out of fuel, helps keep the carb clean.
__________________
stock bottom end 5.0, with stock cam, trick flow 185 heads, air gap intake, powerjection, and a T70 turbo.
MaverickDan is offline   Reply With Quote
Old 2012-06-23, 07:55   #3
Jsarnold
Senior Member
Jsarnold's Avatar
Vehicle(s): '72 Sprint
Images: 13
Do you close the fuel line valve and run the fuel out of the carb after each use? If not, the carb is probably gummed up and not feeding fuel except on choke.
Jsarnold is offline   Reply With Quote
Old 2012-06-23, 08:16   #4
scooper77515
Images: 19
Yes, I always run it dry, then choke it to continue running until it is completely dry. I just drained and cleaned the tank, and replaced the fuel filter/petcock assembly, and the old filter and lines look fine.
I will put it all back together and fill it with fresh fuel and squirt some seafoam aerosol into it and give it a "carb cleaning" and see if that helps.
__________________
Old 2012-06-23, 08:37   #5
Dave B
MCCI Ontario Rep.
Dave B's Avatar
Vehicle(s): 3 Grabbers
Images: 34
Take the float bowl off the bottom of the carb, and see if there is a small hole drilled in the bolt that holds it on, make sure it's clean. The engine on my snowblower does that from time to time, I use stabilizer, and always run it dry in the spring.
__________________
Dave B is offline   Reply With Quote
Old 2012-06-23, 08:39   #6
Jsarnold
Senior Member
Jsarnold's Avatar
Images: 13
Hope the carb cleaning and fresh fuel does it for you. Guess I should get mine out and see if it will start.
Old 2012-06-23, 09:01   #7
scooper77515
Images: 19
It seemed to help a little, but didn't fix it. Wasn't worth the $12 bucks for the bottle of Seafoam. Once again, I am not impressed with the stuff.
So, when the engine cools down, the carb is coming off for a rebuild, or at least a cleaning.
__________________
Old 2012-06-23, 11:10   #8
scooper77515
Images: 19
OK, tore the carb down, there was just a couple pieces of crud in the bowl, and the infamous varnish smell. Cleaned it all up, reassembled, and no difference. Still runs fine one or two clicks off CHOKE, but when I flip it any further toward RUN it falls on it's face and dies.
Runs pretty good and putting out 123V with it on semi-choke. Should I just use it like that or am I missing something?
__________________
Old 2012-06-23, 11:13   #9
MaverickDan
I wanna go fast!!!
Images: 3
Running it on choke at all times will use a lot of fuel and could wash out the cylinders. Did you blow through the passages with compressed air?
__________________
Old 2012-06-23, 11:57   #10
scooper77515
Images: 19
Yep. First with carb cleaner, then with compressed air, hit one spot with a q-tip in the throttle body where there was a little brown stain, and slapped it all back together.
No go.
__________________
Reply
Interested in this thread?
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by: vBulletin
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
